Bubbling or Gurgling Sound from Engine - JeepForum.com
post #1 of 23 Old 07-26-2011, 08:41 PM Thread Starter
MORunner
Noticed it for the first time tonight when I pulled it into the driveway. The sound continued for a good 3 to 5 minutes after I shut if off and seemed to come from the engine. The engine was definitely hot from some in town driving on a very warm night with the A/C blasting. The temp guage measured where it always does, around 210ish. I checked for leaking around the radiator and didn't see anything. No other complaints in terms of power or performance. I'm a new Jeep owner (just bought my 2000 Sahara a few weeks ago) so I'm slowly learning what is and isn't typical on a Jeep. Can any other Jeep owners let me know if they've experienced something similar and if it's normal.
MORunner is offline
post #2 of 23 Old 07-26-2011, 08:45 PM
MayRoll
Coolant overflowing into the reservoir.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #3 of 23 Old 07-26-2011, 08:50 PM
tailhole
Get a new rad cap
tailhole is offline
post #4 of 23 Old 07-26-2011, 09:00 PM
danica789
I get the exact same sound. I have replaced the rad cap and I dont see much fluid in the reserve. When i take the rad cap off, the fluid is to the top. I dont see any fluid movement, but you can hear it.
danica789 is offline
post #5 of 23 Old 07-27-2011, 07:32 AM Thread Starter
MORunner
So is that normal MayRoll? Assuming it's doing what it is designed to do when it get hot, but maybe not.
MORunner is offline
post #6 of 23 Old 07-27-2011, 12:16 PM
mightydog78
get a higher pressure rated radiator cap than the stock. everyone always recommends that.
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #7 of 23 Old 07-27-2011, 12:35 PM
oldmots
The sound is coolant boiling at hot spots in the cooling system. It can be caused by low cooling system pressure or overheating. When the engine is shut off hot, the hoses should be hard for a little while, if they are not, you have low pressure.
oldmots is offline
post #8 of 23 Old 07-27-2011, 12:56 PM
BYuen
BYuen's Avatar
Get a new radiator cap from Napa or similar. 18 lbs is the factory rating. They are really cheap. You might also have some air trapped in the system. To burp the system, start the Jeep cold with the radiator cap off and let it get up to full operating temp with the heat on high. Then put the new cap on and you shouldn't have anymore gurgling.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #9 of 23 Old 07-27-2011, 02:55 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Why?...
Knuckelhead is offline
post #10 of 23 Old 07-27-2011, 06:20 PM
mightydog78
Originally Posted by Knuckelhead View Post
Why?...
so the fluid runs through the heater core and hoses. I guess to get any air pockets out?
^that is your trademark sire
2013 JKU Sahara
Mechanical Engineer
post #11 of 23 Old 07-27-2011, 06:35 PM
Knuckelhead
AFSOC Retired
With a TJ, when the engine is running the coolent is always flowing through the properly operating heater core...
post #12 of 23 Old 07-27-2011, 07:11 PM
phillies4752
phillies4752's Avatar
I have always heard the bubbling after I have shut off my Jeep. I always thought it was normal
I MAKE POOL BALL SHIFT KNOBS FOR $15
PM me if interested
Got Balls?
phillies4752 is offline
post #13 of 23 Old 07-27-2011, 07:38 PM
freeskier93
You may also be hearing oil trickling back into the oil pan...
freeskier93 is offline
post #14 of 23 Old 07-27-2011, 10:07 PM
conrasm
conrasm's Avatar
That was my thought. I hear it draining back into the pain everynight when I get home and it's quiet in the garage.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #15 of 23 Old 07-27-2011, 10:44 PM
oakmckinley
I would add coolant to the overflow.
When the system is hot it expands to the overflow and when it cools it pulls from the overflow, if the overflow is empty or near empty, it's pulling in air.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
coolant , gurgling , radiator cap
97 Sahara - HORRIBLE gas mileage, check engine light, gurgling sound from gas tank JeepGuy425 TJ Wrangler Technical Forum 6 05-09-2012 09:12 AM
Got 'perculating' in the engine. (you know, bubbling sounds like a coffee pot?) Erik T. TJ Wrangler Technical Forum 8 04-27-2010 01:46 PM
bubbling exhaust johnroot01 YJ Wrangler Technical Forum 9 10-05-2009 01:40 PM
Bubbling Paint Flyusaf2002 TJ Wrangler Technical Forum 3 12-22-2004 09:10 AM
gurgling sound from the engine?? TJdave TJ Wrangler Technical Forum 5 04-27-2004 02:06 PM
