#31 | ||
Web Wheelin'
Thanks
Looks good, you have a couple of my future mods already, lockout hubs and rockers.
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! |
#32 |
I made the site tube by tapping the center of the plugs to 1/8" NPT and putting some brass fittings in.
The filter set-up is just an aftermarket remote filter mount... |
#33 | |
Web Wheelin'
Cool, I might be doing that soon. Thanks.
#34 |
Do you have a link?
06 Solar Yellow AT Banks Headers, ARB Periscope, Clayton LA/TT, Coast 1350 Shaft, JKS BL/BMML/Quicker Discos/Adj BumpStops, RE 4.5 Springs/BrakeLines/HD TB, Currie Steering, VVME 3000k, 6000k HID Systems, IPF H4 Headlights, 315/75/16 Nitto Terra Grapplers on Moab's, 5.13's and TruSpeed |
#35 |
#36 |
Subscribed. Thanks.
Sometimes there is justice, Sometimes there is just us. |
#37 | |
Web Wheelin'
It's been a little while since I did any mods, but last night I was trying to replace the rear shocks and broke the upper mounting bolts off again. (it has happened twice before.)
Instead of repairing and reusing the original flawed design again, I have decided it is time for an upgrade and will be doing the outboard shock mod as pioneered by mrblaine. For the rear shocks I am going to use BDS 5500 Series hydraulic shocks, part # 55650 which has an entended length of 26.20 inches, collapsed length of 15.80 inches, with travel of 10.40 inches. The body diameter of the shocks is 2 3/8" for reference. My choice of length was based upon discussion with mrblaine and the fact that my Jeep only has a 2.5 inch lift on it, and I have no intention of lifting it higher, so these should provide all of the travel that my suspension will require. To fab the mounts I will be using the Ford shock towers (part #E5TZ-18183-A), my local Ford dealer actually still stocks these, he sold 6 this morning!! For the lower shock pin I am using Dorman / Motormite # 31001 shock bolt kit available at CarQuest. The shoulder area is 5/8" diameter with a length of 1.25" which works out perfectly for the compressed length of the BDS shock bushings. Pics to come as I will start the fab work tomorrow morning (my wife won't have any part of me doing this today on our anniversary) LOL ![]()
#38 | |
Web Wheelin'
A big Thank you goes out to Stu for his write up on relocating the shocks and also to Humboldt for this one: http://www.jeepforum.com/forum/f9/outboarding-rear-shocks-upper-spring-bucket-relocation-929056/ they both have been very helpful on doing this mod. Also to mrblaine for all of answering my questions, and being willing to answer the phone when I call.
Well, as part of this, I decided to relocate the upper spring buckets also due to the stress placed on the coils. ![]() ![]() In the process of taking things apart, I found this. ![]() ![]() On both rear springs to bottom coil was broken off, so a quick call to Brad at Diversified Creations had a new set of BDS coils on the way for the morning. So the first on the agenda was to remove the spring buckets, trim and reposition them. ![]() ![]() ![]() ![]() Some new bumpstop extensions made up, 1" tall, also much better contact than before to the lower. ![]() ![]()
#39 | |
Web Wheelin'
Once I was Happy with the spring bucket locations, I welded them in solid.
![]() ![]() On to the lower shock mounts, I cut off the factory mounts and replicated what mrblaine did on stu's Jeep, I made up some skids for the control arm mount and then placed my shock mounts onto them. ![]() ![]()
#40 | |
Web Wheelin'
I decided I was unhappy with lower mount angle, so I cut them off and remade them.
![]() After the angle was corrected I could move on to the upper lay-out. ![]() ![]() In the mock up I found the bump stops to still be a little short so I remade them to 1 3/4". (not welded yet) ![]() The shock tower, cut to length ![]() No going back now!!! ![]() ![]() Full bump, both sides ![]() Full bump pass side, full droop drivers side ![]() Full droop pass side, full bump drivers side ![]() Ride height ![]() More tomorrow.....
#41 |
Very cool, why didn't Mopar mount the upper coil buckets in that spot originally?
1997 TJ Sport 4.0 Dark Montego Blue AX-15 |
#42 | |
1999 TJ Sport w/ 3" lift and 33"s. http://www.jeepforum.com/forum/f22/jts-tj-996480/ |
#43 | ||
Web Wheelin'
LOL ![]() ![]()
#44 |
By the way. I really like the way your build is going. Im curious to see how good the ride is after you moved the spring and shocks on the rear. Looks professional too!
#45 | ||
Web Wheelin'
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
