#16 | ||
Web Wheelin'
And a quick pic of the skid mounted during the test fitting process:
![]() Hopefully more to come tomorrow, as I am headed out now to go do more to it. If all goes well, we will be done tonight!! ![]()
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! |
#17 |
nice work
98 tj sahara re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears bulletproof bumpers/tomken skids/tor roll cage warn 9000i |
#18 | |
You got some nasty rust man! Better get under there and give it some tlc with a sander and a can of rustoleum..
My auto racing team (neat website lots of pictures) Stu-offroad, A wealth of information on TJ's! 4x4xplor Motor Oil Myths and Facts (Not sponsored by Amsoil) |
#19 |
Have you thought about adding a site tube to the TC and an external filter to the tranny?...
#20 | |||
Web Wheelin'
Where did you find the sight tube and filter set-up?
#21 | |
Web Wheelin'
Well it's not finished, the exhaust is giving me fits.
It is hitting the trackbar, and the rear edge of the skid, we have two inches of clearance at the front edge, but the way it hangs, the pipe is resting on the rear edge of the skid. We cut off all of the hangars last night, and are re-making them to move to move it around.We stopped at 1:30 this morning and are taking a few days off from it, before we decide to fix it with a proper application of high explosives!! (Not that the wife and family would mind that, right about now. Considering the amount of time this "little" project has consumed lately. )Some clearer pics of the skid mounted: ![]() ![]()
#22 | |
Web Wheelin'
All done, except I am waiting on UPS for my new driveshaft. A front wheel drive Jeep SUCKS in a blizzard.
![]() Anyhow here are more pics. Snow still packed into the undercarriage 12 hours later: ![]() Snow and a good view of the trans temp sensor in the pan. ![]() The new deep trans pan (part #P4007886AB) (Re-usable pan Gasket, part # 429587AC) : ![]() ![]() One more unforeseen complication was that the deep trans pan would not clear the original mount location on the new skid, because of the low mount that I used for this. The solution we came up with was to cut out the forward inch of it slightly wider than the pan and flip the cut out piece back in and weld it so there was no lose of strength. In this pic you can see where the OEM mount bolts would go through the beveled section, we cut into that area in the center of the forward bolt holes and cut out the lower welds to remove the section. ![]() ![]() From underneath, you can see where we moved the reinforcement to. ![]()
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! Last edited by brunosplace; 02-20-2010 at 10:05 AM.. Reason: added part #'s |
#23 | |
Web Wheelin'
Now the Actual Clearance Gain:
Before: ![]() After: ![]() ![]() 12" at the low point to start, and ending at 14.75" all the way across when done. Not a bad increase in clearance considering that No body lift was used for this.
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! Last edited by brunosplace; 04-06-2009 at 03:42 PM.. |
#24 | |
Web Wheelin'
Got the new drive shaft from Coast Driveline installed tonight. Ended up at 17 degrees with the pinion set at 16 degrees. NO vibes,, YAY!!!
pics coming soon:
#25 | |
Web Wheelin'
New drive shaft:
#26 |
![]() ![]() Simply Marvulous ![]() ![]()
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD |
#27 | |
Web Wheelin'
Thanks, it took a while, but I think it turned out well.
#28 | |
Web Wheelin'
More before & after
before: ![]() after: ![]() before: ![]() after: ![]() As you can see in the last two, the skid is almost level with where the t-case drop was before ![]() I am glad I did this mod!!![]()
#29 |
Recently Flopped!!
Looks great!! A TT is on my list for future mods for sure!!
The only thing I know is ... I know nothing!! Insert clever saying by someone well known here... Under Re-construction..... |
#30 |
Nice color
....here is mine...it's changed a bit from when this picture was taken...no more MTRs back to BFGs and it has an antirock now...![]() ![]() Trey |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
