Brown liquid in radiator??? - JeepForum.com
post #1 of 13 Old 03-13-2009, 02:42 PM Thread Starter
mightydog78
I randomly opened the cap to my radiator and found some brownish liquid on the cap and sitting around the opening. I can see the antifreeze in the radiator but this brown stuff is freaking me out
Any idea whatthis is? should I go get the radiator flushed at a local shop just to be safe?
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #2 of 13 Old 03-13-2009, 02:45 PM
prjohnson
Rust??
prjohnson is offline
post #3 of 13 Old 03-13-2009, 02:53 PM
danielgoforth
danielgoforth's Avatar
Is your fluid still the right color? If so then you don't have a problem.
1997 TJ with 4.5 Rubicon Express lift, Warn winch, sliders, 8.8, 5.7L LS1 V8, MTI X1 cam, long tube headers, tune, and a 4L60E.
danielgoforth is offline
post #4 of 13 Old 03-13-2009, 02:55 PM
pmccoy9876
could be stop leak. I know when I used it in my TJ, it kind of stuck around at the cap for awhile.
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
post #5 of 13 Old 03-13-2009, 02:56 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Sounds like coolant needs a flushing.
GOLENJEEPTJ is offline
post #6 of 13 Old 03-13-2009, 03:10 PM
MK116V
Hi dee ho, kids its me Mr. Hanky.
MK116V is offline
post #7 of 13 Old 03-13-2009, 03:24 PM
peeweeXJ
Could be rust or something like Bars Stop Leak. Flush the fluid out and add new stuff.
Good luck.
peeweeXJ is offline
post #8 of 13 Old 03-13-2009, 05:58 PM
GOLENJEEPTJ
Hanky do your profile.
post #9 of 13 Old 03-13-2009, 06:34 PM
rubidriver
I thought mine needed flushing because it was a rust color (19k miles), after draining it I noticed that Mopar used red anti freeze in it that looked rust colored while in the radiator.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #10 of 13 Old 03-13-2009, 09:40 PM Thread Starter
mightydog78
i think ill flush it to be on the safe side
easy to do by yourself? again..im still learning
where is the drain plug located?
2013 JKU Sahara
Mechanical Engineer
post #11 of 13 Old 03-14-2009, 01:51 AM
JakeAW
Drain plug is on the bottom passenger side of the radiator, it looks like a hose spigot. Just an FYI my radiator fluid always looks brown, I've flushed it yearly for a awhile, I'm not sure what it is, but everything seems to be operating normally. Heater core, hoses, water pump, and thermostat all in good shape. My guess is it's the radiator just being nasty and the stop leak stuff I put in it.
'98 TJ Emerald Pearl Coat
JakeAW is offline
post #12 of 13 Old 03-14-2009, 05:25 AM
JeepJeffW
Do a search for "radiator flush" and you'll get a couple of methods. Here's mine. Get the flush kit from Prestone if you're going to go that route. It has a diverter that fits in the radiator cap opening and guides the flushed fluid away from the vehicle and, in my case, into a five gallon pail. When you cut the heater hose running along the engine (its the inlet to the heater core) and install the garden hose you will get a complete flush for as long as you want.
On thing I do is add the chemical in the flush kit to the old coolant BEFORE I flush it, run the engine a little to get it dispersed throughout the system, and the let it sit for about 15 minutes before doing the actual flush. While the chemical is doing its thing I kill the time by cutting the heater hose, installing the "T" connector and getting everything ready for the actual flush.
Lastly, after I finish the flush I disconnect both hoses from the heater core and flush it again in both directions, starting with the inlet (top on mine) to insure it is clean.
Regarding the thermostat, I use the 190 (actually a 195 if I remember correctly).
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
post #13 of 13 Old 03-14-2009, 07:46 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2. coolant pH changes over time and eventually turns corrosive enough to eat your radiator, engine block and heater core apart. the brown stuff is the dissolved components of your cooling system. flush & change the fluid before you have to replace someplace expensive.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
Black Liquid From Exhaust Sundog YJ Wrangler Technical Forum 18 01-13-2010 10:36 PM
Leaking radiator/liquid aluminum? Deadhorse TJ Wrangler Technical Forum 1 03-22-2009 05:04 AM
white liquid? newYJfan YJ Wrangler Technical Forum 2 07-21-2007 03:23 PM
brown sludge in the radiator......please help triple recto TJ Wrangler Technical Forum 16 07-16-2007 12:24 PM
Liquid Gasket Material Zinkart TJ Wrangler Technical Forum 1 03-12-2007 06:58 PM
