Brown Dog MML - JeepForum.com
post #1 of 30 Old 01-21-2008, 12:23 PM Thread Starter
USCGTWEET
USCGTWEET's Avatar
Brown Dog MML
I am installing the MML and I would like to upgrade the hardware to something of the Grade Eight Verity.Can anyone give me a bolt size and recommendation? I figured someone has done this in the past?Thanks All
USCGTWEET is offline
post #2 of 30 Old 01-21-2008, 02:08 PM
HowIRoll
HowIRoll's Avatar
are you installing this without a BL? just curious if it could be done.
Check out my build thread:
http://longhornfabshop.com/
HowIRoll is offline
post #3 of 30 Old 01-21-2008, 02:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's no need for Grade 8 bolts for your engine mounts, I would (and did) just reuse the OE mounting bolts which are way more than strong enough.
And yes HowIRoll, a 1" MML can be installed without a body lift. You'd need to move the fan shroud up an inch but that's all.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 30 Old 01-21-2008, 03:11 PM Thread Starter
USCGTWEET
USCGTWEET's Avatar
Thanks I appreciate it. I am installing a 1.25 JKS at the same time.
post #5 of 30 Old 01-21-2008, 04:35 PM
Baotchi
Baotchi's Avatar
2010 JK Wrangler
I installed the Brown Dog MML before I had my BL. I moved the shroud 1" up and it went well. I also reused the stock bolts.
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
post #6 of 30 Old 01-21-2008, 04:58 PM
Brown Dog
Vendor
Brown Dog's Avatar
We recommend the re-use of the original hardware. They are hardened.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #7 of 30 Old 01-22-2008, 07:13 AM
HowIRoll
HowIRoll's Avatar
Thanks for the help guys, sorry if I hijacked OP.
HowIRoll is offline
post #8 of 30 Old 01-22-2008, 07:43 AM
Brown Dog
Vendor
Brown Dog's Avatar
A few words about MMLs
Some people say that a MML must be used with a body lift; that is a myth. Motor mount lifts and body lifts are not related except that it would eliminate the need to re-locate the radiator or radiator shroud. Neither of those are a valid reason for a MML.
Under normal circumstances, motor mount lifts have only one purpose: to help correct driveline angle issues that are causing vibrations and/or u-joint binding. Therefore, it isn’t really possible to calculate which (if any) MML is needed, simply by knowing how much lift is installed on a given vehicle.
That having been said, most vehicles that have as much as 6” of suspension lift would probably use a stock height, or a 1” MML (again, depending on the remainder of the configuration). A 2” MML has no place in this kind of vehicle.
For further information on correct drive line angles, go here and click on the links about halfway down the page. They do an excellent job of describing the elements of drive line angle.
http://www.browndogindustries.com/in...on=Custom&ID=5
Some abnormal circumstances in which MML's may be useful include custom frames, custom engine installations, or bodies that require a particular engine position due to an out of the ordinary configuration. These are also the kind of designs that might need a 2” MML. Most typical lifting and modification of stock vehicles do not fall in this category.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #9 of 30 Old 02-22-2008, 09:33 PM
JEEP97TJ
Would the T-Case Shift linkages be ok, or would they most likely need adjustment or a bracket to correct them? Also, what modifications would be needed on the radiator shroud to allow a MML without a BL?
Thanks
Blacksburg, VA
JEEP97TJ is offline
post #10 of 30 Old 02-22-2008, 10:56 PM
Jerry Bransford
Administrator
A MML lifts the engine an inch, which also raises the fan which fits inside the fan shroud attached to the radiator. So to install a MML without a BL, you only need raise the fan shroud or radiator a corresponding inch so the fan shroud clears the fan as it did before the MML was installed. That is all.
Getting
post #11 of 30 Old 02-22-2008, 11:35 PM
F9K9
F9K9's Avatar
Being a newbie TJ owner with moderate XJ background I can't express my appreciation for this VENDOR'S input and his/her timing enough. I have been researching, reading, trying different search techniques, lurking and even posted a question without feeling the need to seek cover. I would have lost a few paychecks if, I was asked to bet if, I thought the difference between the two platforms was this extreme.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #12 of 30 Old 02-23-2008, 04:18 AM
john NC
john NC's Avatar
Brown Dog,
what torque spec do you recommend for the through-bolt? i torqued mine to 48 per the service manual but i've seen everything from "snug" to 70 ft/lbs recommended.
btw, couldn't be happier with my MML, great product and price
john NC is offline
post #13 of 30 Old 02-23-2008, 05:19 AM
MEnginerd
I just got a set of the 1" MML from brown dog. Great service, delivery, price, and welds. Paint was a bit thin at the edges, but i don't think anyone is going to notice after they are installed. I'm actually thinking about installing them this afternoon, maybe by tonight i'll be able to comment on ease of install and any increase in vibes from the poly bushings, hahaha. I'm hoping I don't run into a ridiculous amount of grinding on the stock motor bracket, it just doesn't look like a fun place to try to stick a grinder....
-Brent
MEnginerd is offline
post #14 of 30 Old 02-23-2008, 09:23 AM
Brown Dog
Vendor
Brown Dog's Avatar
-Brent
You should fill out your profile so members know how to better help you. You only need to grind if you have a 2.5 YJ with aluminum brackets.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #15 of 30 Old 02-23-2008, 09:24 AM
Brown Dog
Vendor
Brown Dog's Avatar
Originally Posted by john NC View Post
Brown Dog,
Snug, as long as the lock nut is in good, working condition. Otherwise, replace the locknut.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Brown Dog MikNov TJ Wrangler Technical Forum 30 10-23-2009 11:51 AM
Brown Came!! BiGEN JK Wrangler Technical Forum 31 09-21-2008 01:12 PM
MML: M.O.R.E. or Brown Dog BYuen TJ Wrangler Technical Forum 24 05-01-2008 09:49 AM
Brown Dog MM USCGTWEET TJ Wrangler Technical Forum 2 01-16-2008 05:34 AM
MML- Brown Dog vs. M.O.R.E. KUK9 TJ Wrangler Technical Forum 18 03-08-2007 05:43 PM
