Brown Dog MM - JeepForum.com
post #1 of 3 Old 01-16-2008, 01:42 AM Thread Starter
USCGTWEET
USCGTWEET's Avatar
Brown Dog MM
So I recently purchased a set of Brown Dog MM to help with me body lift I will be installing shortly and I was just curious as to what was supposed to be included in the packaging as I bought these second hand. All they came with were the mounts no hardware, is this correct?
Also I was quoted 166 for the JKS 1.25 BL with military discount from 4Wheel Parts does this seem Hi to anyone else I have be seeing more the 120 range?????
THANKS ALL!!!!
USCGTWEET is offline
post #2 of 3 Old 01-16-2008, 02:12 AM
Delta9
Delta9's Avatar
yes $120 or lower, and yes just the mounts
Delta9 is offline
post #3 of 3 Old 01-16-2008, 06:34 AM
VinoTJ
VinoTJ's Avatar
If you have AC in your heep, make sure you reverse the driver's side through-bolt as it is a PITA to get at (need to access from underneath) - in case you ever need to access again.
2008 Wrangler Unlimited X
VinoTJ is offline
Brown Dog MikNov TJ Wrangler Technical Forum 30 10-23-2009 12:51 PM
Brown Came!! BiGEN JK Wrangler Technical Forum 31 09-21-2008 02:12 PM
MML: M.O.R.E. or Brown Dog BYuen TJ Wrangler Technical Forum 24 05-01-2008 10:49 AM
Brown Dog MML USCGTWEET TJ Wrangler Technical Forum 29 02-27-2008 09:19 PM
MML- Brown Dog vs. M.O.R.E. KUK9 TJ Wrangler Technical Forum 18 03-08-2007 06:43 PM
