Brown Dog MM and 2.5L? - JeepForum.com
post #1 of 8 Old 04-24-2011, 03:51 PM Thread Starter
man44a
Does anyone else have the Brown Dog Motor Mounts and the 2.5L engine? I just got mine installed along with body lift and OME lift. The engine now has a really bad sound at around 3000rpms. It sounds like an import with those big exhausts.
Im wondering if anyone else has put this on their jeep and had this problem? I thought it could be a hole in the muffler, but the shop that did the lift says its due to the mounts. I was expecting more engine vibes, but this sound is aweful. I am using the rubber, not polyurethane.
Any similar experiences with other brand MM's?
Any other ideas what would cause this?
http://youtu.be/w3OEyf6PNWc
man44a is offline
post #2 of 8 Old 04-24-2011, 04:00 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I have the 4.0 with Brown Dog rubber mounts and there are no vibes what so ever.Personally I think your shop is full of it... putting the blame on your Brown Dog motor mounts!Are they the standard mounts or lifted?
GOLENJEEPTJ is offline
post #3 of 8 Old 04-24-2011, 04:00 PM Thread Starter
man44a
The lifted mounts
man44a is offline
post #4 of 8 Old 04-24-2011, 04:00 PM
GOLENJEEPTJ
Also you really need to fill in your profile.
post #5 of 8 Old 04-24-2011, 09:27 PM Thread Starter
man44a
Solved!!!
So the noise was coming from the motor mounts. I loosened the through bolts and when I did, noise is gone. Now I tightened them back without torque wrench and I can still barely hear it.
How loose can I make the through bolt without it causing a problem?
man44a is offline
post #6 of 8 Old 04-24-2011, 09:39 PM
Prunetuck4X4
Loose motor mount bolts are NOT the way i would want to solve a problem regardless of the situation that would be my LAST option to resolve the problem. Just sayin'.
"I wasn't sleeping i swear, I was just reading a thread about drum brakes."
Once you start with the basics it becomes like a wife or girlfriend, you will not want another mans hand all over her, you will want the work all to yourself! -freedommachine
Prunetuck4X4 is offline
post #7 of 8 Old 04-24-2011, 09:48 PM
danb303
THose bolts are not supposed to be real tight. I did the same thing on my old jeep and had to go back a torque them to spec. If you tighten them too tight they clamp the metal bushing and then you basically have metal on metal mounts.
check the torque specs. I can't remember but I am thinking it's 30 ft lbs???
danb303 is offline
post #8 of 8 Old 04-26-2011, 08:35 AM
Brown Dog
Vendor
Brown Dog's Avatar
If the locknut is in good condition, you can have it as loose as you need it to stop the vibration until you find the source of the problem. I have new locknuts if you need, but can't find one.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
Brown Dog MikNov TJ Wrangler Technical Forum 30 10-23-2009 12:51 PM
Brown Came!! BiGEN JK Wrangler Technical Forum 31 09-21-2008 02:12 PM
MML: M.O.R.E. or Brown Dog BYuen TJ Wrangler Technical Forum 24 05-01-2008 10:49 AM
Brown Dog MML USCGTWEET TJ Wrangler Technical Forum 29 02-27-2008 09:19 PM
Brown Dog MM USCGTWEET TJ Wrangler Technical Forum 2 01-16-2008 06:34 AM
