#1 | |
Brown Dog 1" Motor Mounts
I'm about to go with a body lift and want to use the Brown Dog 1" Motor Mounts, which I hear are excellent products. Anyone out there have any recommendations on whether to get the rubber ones or polyurethane? Their site just says that the poly's give it a more "sporty" feel. My guess would be that it would have more vibration than the rubber also. Just curious if anyone has these and can offer any input. Thanks!!!
#2 |
Rubber is softer and will absorb more vibrations than polyurethane. Rubber will also (generally) have a shorter life span than polyurethane, but I don't see that being a big issue in the real world.
2005 Unlimited, 4.0L, 4sp auto, 3.73 stock gears, BDS 3" lift w/ 3/4" Daystar coil spacers up front, BDS front adjustable trackbar, BDS 5500 shocks, Rough Country X-Flex lower control arms, JKS 1.25" body lift, JKS BMML, AR Outlaw II 15x8 wheels, BFG AT 33x12.5 tires, AtoZ rocker guards, Rokmen belly-up transfer case skid, homemade 1.5" gas tank lift |
#3 |
I had poly browndogs on my XJ. they were standard height. supposedly an XJ gets much more vibration from poly mounts because of being a unibody and not having the body/frame insulators to soak up the vibes. it makes sense to me. nonetheless I felt next to no vibrations with mine. you notice it a little bit at first but after a week or 2 you really dont notice any vibes anymore. what I DID notice is I was hearing more of the engine's exhaust tone. maybe people would more likely classify it as just engine noise but on mine it definitely gave the engine more "tone".
I have stock rubber mounts on my new to me LJ rubi. but once the $$$ allows I absolutely plan on adding brown dog poly mounts to my rig. I'd say go with the poly's simply because unlike the rubbers, you know you will never have to change em out again. not to mention they are cheaper.
DAILY 96 S10 ex cab stepside 4.3 5spd ZQ8 05 LJ RUBI 6spd 2" BB, 1.25" BL, RE genII disco's, 33" procomp XMT's |
#4 |
Running Secretly Amok!
Rubber the only way.I have Brown Dog standard mounts and there just fine!Got rid of the daystar engine an trans mount which were poly.Way better now!
#5 |
I have the Brown Dog rubber MML and am pleased with it. I have read several posts on the forum where people have regretted using poly mounts due to engine vibes. When I took the OEM mounts off - 5 years old, they were in great shape. I don't envision these new ones wearing out for a long time.
gmb08 |
#6 |
used rubber, still feels stock. bd was a good company to deal with, I like mine so far.
#7 |
FWIW, I have a Currie poly MML and I feel very little vibes from the engine due to the MML. I feel them slightly at a stop light and only while in drive. When I put it in Neutral or Park, the vibes are gone.
BUT - My engine skid plate mounts directly to the underside of the motor mount on the frame side, and connects directly to the transmission skid plate. Wth the engine skid plate on the engine vibes get a little more noticable, but same thing - put it in park, they disappear, put it in gear and they are apparent ONLY when stopped. Once the engine is over idle, you never feel them.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#8 |
i had poly brown dog mml on my old jeep and i didnt feel much of a difference from stock but it definitely helped my driveline angle a lot
#9 |
I think I see a line...
I have the Brown Dog 1" lift poly mounts. Go with the rubber! I have quite a few engine vibes with mine, enough to make the rear view mirror blurry. Torque on the mounts is essential to how much vibes you will get with the poly. I have been thinking of buying the rubber bushings to replace mine to get out of that but otherwise the mounts are great. Top quality product!
2004 Wrangler X, 6-cylinder, 5-speed, Dana 30 w/ARB, Alloy USA front shafts, Dana 35, 2" BB, 1" BL, OME shocks, Brown Dog MML, UCF Ultra High-Clearance Skid, Lo-Pro Mount, SYE, Pro Comp Adj. Control Arms, Savvy Gas Tank skid, JKS Quick Disconnects, Rock Hard Sliders, 31" BF Goodrich KM2's on Ravine wheels, Hard Top, Bestop Soft-top, Bestop Safari Top 2010 Moab Trip Thread with JeepForum Members http://www.jeepforum.com/forum/f95/idaho-jeep-moab-2010-a-1038859/ |
#10 |
I had the poly mounts when rubber was not available, there was alot of vibrations esp with the a/c on...
When they came out with the rubber mounts i called Brown Dog up and they sent me the rubber one's. I switched them to rubber and am very pleased They are a company who stands behind their product i would definitely but from them and get the rubber one's! |
#11 |
Junior Member
I have the the 1" MML with poly mounts and notice vibrations when idling only. They are not bothersome. In fact, I like them...
#12 |
Had poly on last jeep, tried rubber on this one. Recommendation - go rubber!
#13 |
Years ago when I was researching doing a 1" MML I talked with an engineer who enlightened me to some things I didn't know.
If you install poly motor mounts and leave the OEM rubber transmission mount in place, your creating harmonic imbalance. If you install the poly transmission mount with the poly motor mounts, you have harmonic ballance. I had vibration with the miss matched rubber/poly mounts. I have no vibration with all three mounts being poly in my 2000 Sport with an automatic transmission when stopped in gear, or in neutral... |
#14 |
We run brown dog poly mounts in both of our jeeps along with poly trans mounts.
The LJ has a slight vibration at idle, but it is livable. I prefer the poly mounts over the softer rubber mounts for the feeling of responsiveness and the lack of deflection helps with the tight tolerances when tucking everything up Go brown dog
Old stretch thread: http://www.jeepsunlimited.com/forums/showthread.php?t=403448 New stretch thread: http://www.rockymountainextreme.com/showthread.php?t=48591 |
#15 |
First off the Brown Dog Mounts are awesome. They are very well built and not a bad price either. I have the poly ones and they do give some vibes. If I had done it again I think I would have done rubber from the beginning though. Not enough of an issue for me to get the rubber inserts and install them though. But I might do it sometime in the near future.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
