Broken zipper on the rear window. How to FIX? - JeepForum.com
 1Likes
  • 1 Post By biffgnar
post #1 of 14 Old 05-08-2011, 02:43 PM Thread Starter
BRay09
1997 XJ Cherokee
Well we were taking the top off for the first time that we had the jeep and everything came off kinda hard. All the zippers were corroded and one of the zippers in the rear were heavily corroded. I put PB on all of them before i started and ended up breaking off the zipper on the driver side of the rear window. now the only zipper that holds the window on is the right half. How would i go about fixing this?Should i be looking for a new soft top? Please help!! This is on the 03 wrangler
My jeeps:
1997 Cherokee w/ 4.0L 215K
2003 Wrangler w/ 4.0L 75K
BONE stock.... For the moment!
BRay09 is offline
post #2 of 14 Old 05-08-2011, 02:59 PM
unklej
you can buy the windows individually. I dont know about the zippers. the brand is ykk. you could try contacting them or bestop and explain the situation. they might be able to send you a replacement for a couple bucks. quadratec also sells a zipper lube and cleaner that has a little brush on it to keep them clean and free moving for the future. hope this helps!!
unklej is offline
post #3 of 14 Old 05-08-2011, 03:36 PM
mediumdaddy
i've heard of using candle wax to keep zippers working smoothly. i havent tried it yet, but im going to if it will stop raining outside!
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #4 of 14 Old 05-08-2011, 04:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You can get a replacement YKK zipper piece at most yardage stores.
Jerry Bransford is offline
post #5 of 14 Old 05-08-2011, 04:58 PM Thread Starter
BRay09
1997 XJ Cherokee
This my be a dumb question, but how does the top come off? dow you take off all the windows and then just fold it down or can you just fold the top back with the windows on?
Also, how does the back window come off? does the zipper i broke act as the beginning to the zipper? or do you just zip them both to the middle and fold the widow in?
Sorry for the stupid questions, never had a jeep with a removeable top before.
My jeeps:
BRay09 is offline
post #6 of 14 Old 05-08-2011, 05:03 PM
kahjeep
I always remove windows then lower top. Zip from one side to the other. Never tried leaving back window in. I wouldn't really try it that way.
kahjeep is offline
post #7 of 14 Old 05-08-2011, 05:29 PM
thirdeye
I just roll my back window up with the zippers up to the top on each side. To take it off you have to get both zippers to one end. I just take the top off usually rather than foling it down. Theres 4 torx screws on the softtop frame attached to the roll cage then just undo all the trim pieces. There's two clips above the sun visors and the trim attached to the door surrounds and the back corners, that just pop out.
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #8 of 14 Old 05-08-2011, 05:58 PM
liftedon37s
http://jeepit.com/zipper3.htm
They sell just the zippers. I have never bought from them tho. I ended up getting a smoking deal on a new top so I didn't have to replace my rear zipper.
I use a liquid silcone on my zippers now.
It has some things done to it.
liftedon37s is offline
post #9 of 14 Old 05-08-2011, 07:39 PM
MooSe7
Bar of soap
2004 Wrangler Sport
2006 Grand Cherokee Laredo
MooSe7 is offline
post #10 of 14 Old 05-08-2011, 08:59 PM
CJ Chet
Originally Posted by MooSe7 View Post
Bar of soap
Works well;!!!!!!!!!!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #11 of 14 Old 09-07-2017, 08:39 AM
Gabety
This doesn't help with the problem I have. My zipper on the rear window operates fine except the zipper separates again as soon as it is zipped. What is the solution to that?
Gabety is offline
post #12 of 14 Old 09-07-2017, 09:05 AM
biffgnar
biffgnar's Avatar
Give the zipper body that meshes the teeth together a bit of squeeze with a pair of pliers to tighten it up. They can get a little loose and not create a tight mesh with the teeth. Tighten them up and you might fix your problem. Either that or the whole things needs to be taken off and new one sewn on.
JStMarie likes this.
biffgnar is offline
post #13 of 14 Old 09-07-2017, 03:21 PM
Jeepit85
Soap is the answer? Doesn't that attract dirt?
85 CJ7, Howell TBI, Twin Stick, 4:10's, 35" Pitbull Rockers, Clifford 6=8, Detroits, Matkins Level II, BDS 4", Summers Brothers. Skynyrd rocks.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #14 of 14 Old 09-08-2017, 11:52 AM
TJnBC
I use chapstick or board wax on my soft tip zippers
my rear window zipper was skipping a couple teeth recently. Made it a ***** to take off. Used Biffs method of some needle nosed pliers and squeezed them tighter. Worked great.
2006 LJR...the madness begins again
TJnBC is offline
broken window zipper _TIM_ Wrangler General Discussion 4 07-12-2009 11:30 PM
Broken back window zipper scutt TJ Wrangler Technical Forum 7 06-05-2009 04:25 PM
Rear window zipper broken CO_crawler TJ Wrangler Technical Forum 1 05-07-2009 07:03 AM
Broken Zipper On Bestop Back window Didley TJ Wrangler Technical Forum 13 04-25-2009 04:11 PM
Rear window zipper? jblfitness TJ Wrangler Technical Forum 8 08-03-2006 01:42 PM
