Broken Vacuum Line =Rough Idle? (PIC) - JeepForum.com
post #1 of 8 Old 12-22-2010, 11:21 PM Thread Starter
04Wrangler2000
I replaced an exhaust manifold gasket last week and in the process broke a vacuum line.. I repaired it by sliding a small metal tube over the two broken ends then put heat shrink over the metal tube and lines to seal it..
I've got a slight rough idle down under 1000k rpm.. Would this be the cause since it's not a perfect line..
Is that a part the dealer would have? Would I have to buy the entire vacuum line assembly? and How much it would cost?
Also curious what this line is connected too? I would appreciate any feedback..
04Wrangler2000 is offline
post #2 of 8 Old 12-22-2010, 11:31 PM
LimeLJ
LimeLJ's Avatar
That is the cruise control vacuum servo. You can get the official part from the dealer, but you can also buy some vacuum hose from an auto parts or hardware store.
LimeLJ is offline
post #3 of 8 Old 10-25-2011, 07:18 PM
I need that hose as well since I bought a used cruise control kit. I'll call the dealer tomorrow, but maybe someone has a ballpark figure for price on just the vacuum tube. I don't want to use a generic hose.
????? is offline
post #4 of 8 Old 10-25-2011, 07:44 PM
chris142
Why not? That plastic line gets brittle and breaks. Rubber hose gets rotten but usually out lasts the plastic line plus the hose is like $.20 a ft.
chris142 is offline
post #5 of 8 Old 10-25-2011, 07:54 PM
freeskier93
Duct tape?
freeskier93 is offline
post #6 of 8 Old 10-29-2011, 11:02 PM
I just prefer a factory look. I have some 3/8" hose for it, but it's a bit awkward compared to the narrow vacuum tube with the 90 bends in it.
????? is offline
post #7 of 8 Old 10-29-2011, 11:29 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Disconnect that line where it Ts near the manifold & plug the T with your finger & see if the idle smooths out. If not then you may have another cracked line. The line that goes from that T to above the battery which controls the heater vents is also prone to cracking. If all your heat only comes through the defroster vents that line is cracked.
Rubi4MyMrs is offline
post #8 of 8 Old 10-30-2011, 01:52 AM
Necko2529
Necko2529's Avatar
I blew cigarette smoke in mine to see if it was cracked, sure enough, the smoke started coming out of it along the firewall. It got chafed rubbing against the firewall and was leaking. Cut in half, slide a piece of rubber hose over and seal. It fixed the leak and should take a lot longer to rub through to make it leaked again...
You shouldn't be afraid of using rubber hose, it would probably do better, I have to take great care moving my stock hoses around, they are really brittle from all the underhood heat. Just get it in black color and it would look stock.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
Vacuum Leaks. Rough Idle. What gives? Urb4nTr0ll YJ Wrangler Technical Forum 17 03-09-2012 12:41 PM
Bouncing Idle after Vacuum Line Reconnected Boston_Wheeler TJ Wrangler Technical Forum 4 07-12-2009 09:08 PM
Broken vacuum line **with pictures** romanella YJ Wrangler Technical Forum 6 12-03-2007 12:20 PM
Oil leaking from vacuum lines and rough idle !! Buckaroo Bonzai YJ Wrangler Technical Forum 3 04-01-2007 09:20 PM
vacuum leak: rough idle: cruise no work markc522 TJ Wrangler Technical Forum 4 06-19-2006 09:33 AM
