Broken torx - JeepForum.com
post #1 of 6 Old 04-17-2004, 08:37 PM Thread Starter
lib
Broken torx
I was trying to take off the overhead soundbar today and got 3 of 4 screws out. On the last one I broke a hardened steel torx bit inside the screw. What is the best way to get the screw out now? ?grind/dremmel/heat/etc.?
lib is offline
post #2 of 6 Old 04-17-2004, 08:48 PM
u4ea
u4ea's Avatar
You can get a screw removal drill bit kit at home depot, lowes etc... they are cheap and easy to use... unless someone has a better idea.
U4EA
eu·pho·ri·a (n. A feeling of great happiness or well-being.)
'03 Sahara - Sienna Pearl Coat - 5 spd
'04 VW Touareg
u4ea is offline
post #3 of 6 Old 04-17-2004, 09:18 PM
socaljeff
yeah sears sells some really nice screw extractors. they can take out just about anything thats stripped
socaljeff is offline
post #4 of 6 Old 04-17-2004, 09:25 PM Thread Starter
lib
That would work except the torx bit broke at the level of the screw head. I tried drilling it out but it is hardened steel and was not affected by my drilling.
lib is offline
post #5 of 6 Old 04-17-2004, 10:01 PM
river rat
Forum porn star...I guess
river rat's Avatar
If you have a Dremel, use a small cut off wheel and cut a slash across the top of the screw. You should have no trouble getting through the bit with that. Then use a big flathead screwdriver to remove the screw.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #6 of 6 Old 04-17-2004, 10:05 PM Thread Starter
lib
That just might work. I will give it a try tommorrow and let you know. Thanks for all the advice everyone.
lib is offline
Broken Torx Screw Extraction eattoast TJ Wrangler Technical Forum 6 09-16-2013 09:19 PM
need help! broken bolt extractor broken. fltj TJ Wrangler Technical Forum 14 04-18-2008 02:32 PM
Sixth broken torx T40 cheesycook TJ Wrangler Technical Forum 28 12-14-2005 09:06 PM
broken torx bit nix_toy TJ Wrangler Technical Forum 11 08-09-2005 10:51 AM
Broken axles, broken carrier and gears.. (pics) Texasmudder TJ Wrangler Technical Forum 34 03-15-2005 10:59 PM
