broken plastic on shift boot - JeepForum.com
post #1 of 23 Old 10-15-2008, 09:10 PM Thread Starter
Timbo
Does anyone know of a place that I could buy a new Shift boot for my heep short of the dealer? I broke the plastic part that pops into the console trying to manhandle it off...now it just flops around on the stick shift...
I've checked boneyards around here to no avail...
Live Free or Die; Death is not the worst of evils
Member: Black Jeep Society
Amateur Radio Call KB1MM
Timbo is offline
post #2 of 23 Old 10-15-2008, 09:15 PM
zachbh
you can buy new actual shift boots at any auto part store, but as for the plastic piece........ dealer?
i dont know go steal one of your friends......
zachbh is offline
post #3 of 23 Old 10-15-2008, 09:18 PM Thread Starter
Timbo
unfortunately, it appears that the plastic piece is molded into the boot. It has four fingers (two on each side) that click into the console plastic and hold it down...
I considered the other alternative you mentioned
Timbo is offline
post #4 of 23 Old 10-15-2008, 09:22 PM
zachbh
molded into the boot?
im not sure what your saying.... do you mean the boot wraps around the plastic piece then the piece snaps into the console? i thought the plastic piece was broken
zachbh is offline
post #5 of 23 Old 10-15-2008, 09:36 PM
Rocky529
Rocky529's Avatar
http://www.jeepsareus.com/Merchant2/...Category_Code=
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #6 of 23 Old 10-15-2008, 09:39 PM
jeepbro's
thats what ya need! i need to get one too, but i'm also going to switch to the boot from the 05-06 ones because right now shifting with out the boot is much easier/smoother to me
EDIT-dang it rocky529 beat me to it! jerk...jk
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #7 of 23 Old 10-15-2008, 09:55 PM
C2U5H
C2U5H's Avatar
X9 on the later model "pleather" shifter boot on earlier models
after my MML & BL it made my shifter sooo much better. plus it looks a hell of a lot better ... i don't know why they ever went back to the corrugated rubber on the JKs
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #8 of 23 Old 10-15-2008, 10:04 PM Thread Starter
Timbo
Yep...that's it! I really thought it was all one piece, bezel and boot...well, raise my rent!
Thanks guys!
Timbo is offline
post #9 of 23 Old 10-15-2008, 10:09 PM
jeepbro's
aright question on getting old shift boot off/putting new on, do you have to take off the shifter knob? my friend put on a hurst t-handle and said his knob pretty much got destroyed trying to pry the shift pattern cap off, and i'm not ready to jump to a diff shift knob
post #10 of 23 Old 10-15-2008, 10:37 PM
kuotown
I broke the plastic ring in my shift boot as well on a wheeling trip. It actually came up and was broken in two different places. I just super glued it back together and put the shift boot back on and then put it into the console. It has held up flawlessly for 6 months now without any problems. It might be worth a shot!
kuotown is offline
post #11 of 23 Old 10-16-2008, 06:46 AM Thread Starter
Timbo
I was thinking the same thing...we have some JB weld here at work...it's worth a shot. I am having problems getting the knob off like jeepbro mentioned...I scarred up the knob trying to get a flat bladed screwdriver under the shift pattern cap to pry it off...it still won't come up. I've always wanted one of those hand grenade shifters...maybe this will "force" me to get one
I may look for one of those "pleather" boots..the rubber/plastic one gets rock hard when the thermometer drops down around the zero mark...makes for hard shifting...
Timbo is offline
post #12 of 23 Old 10-16-2008, 07:12 AM
tj99
tj99's Avatar
One of the corners was cracked on mine when I got it. I used epoxy to put it back together. It held for about six months, I just noticed it had cracked again in the same place, the lower left hand corner. Must be those hard 1-2 shifts I do with the 4 banger
If I fix it again I'll put a little plumbers tape in with it to strengthen it.
1998 2.5L 5Spd - Sold
1999 4.0L Auto - Mine
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
post #13 of 23 Old 10-16-2008, 07:18 AM
Luke4554
damn those seats have seen better days lol
2000 TJ Sport
4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid
Owner of WWAutosports & Pure Bred Fabrications Dayton, Oh
Luke4554 is offline
post #14 of 23 Old 10-16-2008, 09:01 AM
C2U5H
C2U5H's Avatar
i use a heat gun and heat up the plastic around the center cap first, then take an awl and gently pry it up and out. same procedure for putting it back in. mine looks fine and as the plastic cools down, it'll conform back to original (though it may take a day or two)
yeah, i have since removed them and i'm looking for some new seat covers! neoprene never again! they held up for a good 3 years though. it's awesome to see a near-ten year old seat under the cover that looks BRAND spankin' new
- see sidebar
C2U5H is offline
post #15 of 23 Old 11-22-2008, 12:46 PM
dvaldez70
I like the pleather shift boot. I've done a quick look but not finding it. Where can I get one?
dvaldez70 is offline
Broken Plastic piece around stick shift JLCJ7 JK Wrangler Technical Forum 10 12-18-2010 10:42 PM
Gear Shifter Boot Plastic Retainer 200 TJ GIXMAN TJ Wrangler Technical Forum 3 02-05-2010 12:36 PM
Shifter boot plastic frame broken PERTU TJ Wrangler Technical Forum 8 03-31-2007 07:43 PM
Plastic peice that surrouds shift boot termeitz TJ Wrangler Technical Forum 11 09-23-2005 11:19 AM
3.5 RE suspension lift and now a broken shift boot bracket... tunesoul TJ Wrangler Technical Forum 5 01-14-2005 01:17 PM
