broken off spark plug - JeepForum.com
post #1 of 11 Old 06-22-2006, 09:23 PM Thread Starter
bobjp
Does anyone have any tips for removing a broken spark plug? It is sticking out a bit, but the hex part is broken off. It is not easy to get to. I don't want to drill it out until I have exhausted all other options.
any tips would be great
Thanks a lot
97 TJ sport.
bobjp is offline
post #2 of 11 Old 06-22-2006, 10:10 PM
Expat
Frequent flyer
Expat's Avatar
Dude that really sucks. I feel for you. I wish you luck but I forsee a pulled head.
05 RME Fire Red
3.5" RE springs, JKS F&R adj track bars, JKS adj CAs (all 8), OME LT shocks, JKS quicker discos, JKS 1.25" BL, MORE BP MML, 35" Cooper SSTs on 057 Eagle Alloys, 4.56s Detroit lockers, Alloy USA front and rear axles, Currie HD steering, 52" Hanson front bumper, Warn 9.5ti with in-cab control, Kilby steering box skid, Jeeperman rear bumper/tire carrier, Jeeperman trail skidz, 33 Eng TT, JB SSSYE, TW driveshaft, and lots more........
2007 WK Overland Steel Blue..wifes
1997 ZJ Laredo...sons
2004 GMC 2500 HD Duramax Diesel..My TV and DD and Lance camper carrier
2003 Chaparral 223 deck boat
Originally Posted by kjp98TJ
drop the purse, and hit it.
Expat is offline
post #3 of 11 Old 06-23-2006, 08:08 AM
fundabug
fundabug's Avatar
That happened to a guy I work with just last month. He drilled it out, but in the process he got a lot of metal shavings in the cylinder, so he had to clean that out. After about 2 weeks he got it all done himself, but on his way home 2 days later some girl on a cell phone ran a stop sign and totalled his truck.
2004 Wrangler X 4.0 I6 Solar Yellow
fundabug is offline
post #4 of 11 Old 06-23-2006, 08:51 AM
dieseljeep
What the &#@%
What in the heck is going on? I haven't had to worry or mess w/ spark plugs in I don't know how long. I've never even heard of being able to break a plug off below the hex. Is the quality of spark plugs going to crap or is this a Jeep issue?
dieseljeep is offline
post #5 of 11 Old 06-23-2006, 08:58 AM
FLATFENDER54
FLATFENDER54's Avatar
Exactly what I was thinking : How did it break below the hex head area?? Ive broken spark plugs several times on all kinds of vehicles but it was always the porcelean (sp?) part that is sticking out and I was still able to put a socket or spark plug wrench on it to remove and replace it. I cant even see how it could break below that point? How did it happen or what where you doing? Will an easy out work?
FLATFENDER54 is offline
post #6 of 11 Old 06-23-2006, 09:29 AM
TJZep
anything to grab with vise grips?? any way u could notch it and use a flathead screwdriver? How did you break the hex part off? did it happen while trying to remove it? if so maybe it is pretty frozen, in which case u need to drill it out. Please, whatever you do, remove the head before drilling, it will save you alot of headaches later, for the work it will take now to remove it.
97 tj, 33's and a 4 inch lift, locked front and back, 4 banger and proud of it!
Low Output 4 Cylinder Jeep Club Member # 42
TJZep is offline
post #7 of 11 Old 06-23-2006, 12:52 PM Thread Starter
bobjp
It is actually in a ford truck not the Jeep. It broke just below the hex part. There is about a 1/4 to 1/2 inch of metal sticking out. These plug have never been changed as far as I can tell (it's someone else's truck). It broke because it is frozen in there. I am going to try heating it with a torch, but the head is aluminum so I can't get it very hot. I will try notching it and beating with a hammer and screwdriver. Any more tips, post them up.
Thanks
97 TJ sport.
bobjp is offline
post #8 of 11 Old 06-23-2006, 02:12 PM
FLATFENDER54
Dont Heat It If It Has Aluminum Heads They Are To Expensive To Mess Up Plus You Will Not Be Able To Get Just One Head To Relace It. Spark Plugs In Aluminum Heads Need To Have Anti-sieze Put On Hte Threads Before Installing (maybe This Is Why They Are So Stuck) If Vise Grips Or Similiar Doesnt Work I Would Take The Head Of (no Question About It) Its Not That Hard To Remove Fuel Injected Or Carbuerated. It Is Not Fun Though I Just Recently Had To Pull My Aluminum Heads Off Of My Ford P/u Because I Blew The Head Gaskets With Only 6psi Of Boost (think I Ran Low On Fuel Pressure) Anyways It Took Most Of The Weekend On A Fuel Injected Vehicle
post #9 of 11 Old 06-23-2006, 03:02 PM
vector6
Karma..
vector6 is offline
post #10 of 11 Old 06-23-2006, 03:40 PM
bee guz
spark plug
Have you tryed an easy out, if you can drill a hole, but you don't want anything droping into the cyl. hole, or you will have to remove the head.
bee guz is offline
post #11 of 11 Old 06-23-2006, 03:47 PM
JBTJ
[QUOTE=FLATFENDER54] Spark Plugs In Aluminum Heads Need To Have Anti-sieze Put On Hte Threads Before Installing (maybe This Is Why They Are So Stuck) [QUOTE]
VERY VERY true, ask me how I know. Wait a minute, you already know now. I use anti-sieze on all plugs no matter what. Please use from now on untill the day you die.
JBTJ is offline
spark from spark plug! AlaskaJeepMan TJ Wrangler Technical Forum 3 08-20-2010 06:08 AM
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
Spark Plug Gap kc_jeep TJ Wrangler Technical Forum 4 04-13-2008 08:49 PM
Spark plug Help... They are done... Chris_Ryan TJ Wrangler Technical Forum 6 08-18-2006 08:58 PM
Spark Plug Gap AllanAlxndr YJ Wrangler Technical Forum 2 06-13-2003 09:25 AM
