Breather tube - JeepForum.com
post #1 of 5 Old 04-02-2007, 04:28 PM Thread Starter
rocketman121
Breather tube
I recently lifted my jeep about 3 inches and the breather tube for the rear differential isnt long enough anymore. It seems like i could reroute it from another direction, or do i need a new one. I was wondering what you guys did or if you had this problem. thanks
-87 XJ 4.0 5spd, 2"BB, 31" BFG ATs on 15x8 Eagle 058s, trimmed and doorless
-01 TJ 4cyl auto FT 3" lift 33" Goodyear AT/S & BFG muds herculined tub
rocketman121 is offline
post #2 of 5 Old 04-02-2007, 05:52 PM
TJted33
extend it to somewhere higher. many people do this, it wont hurt it
TJted33 is offline
post #3 of 5 Old 04-02-2007, 08:20 PM Thread Starter
rocketman121
bump bump
post #4 of 5 Old 04-03-2007, 02:18 PM
el guapo
I'm looking to do this as well - mine seems to be stretched a little too tightly over the fuel lines after doing my 3" FT lift. Is this any special hose? Do you need any special clamps?
el guapo is offline
post #5 of 5 Old 04-04-2007, 08:43 AM
bradleyfitz
You can just extend the existing one, no need to replace it. You can usually get a length of hose cut to length or buy a packaged length from your local auto store. Just measure the inside and outside diameter of the breather hose so you get the right size extension. Then just buy an adapter to mate the two together.
I think I extended mine 4", at the axle.
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline
Axle breather tube Apex TJ Wrangler Technical Forum 6 02-27-2009 05:42 AM
Breather tube on a D35 Robbypfd YJ Wrangler Technical Forum 7 03-29-2008 06:37 PM
3sp breather tube. 98tjsahara TJ Wrangler Technical Forum 8 09-20-2007 08:59 AM
Differential breather tube 1stJeepyj YJ Wrangler Technical Forum 8 02-24-2007 06:52 AM
Differential Breather Tube Skeezer TJ Wrangler Technical Forum 11 12-26-2006 04:57 PM
