Quantcast Brand new Silla alum radiator leaking? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Brand new Silla alum radiator leaking?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 02-28-2009, 11:37 PM   #1
GreenTJ420
Replaced my radiator with a silla alum one on thursday everything went fine dropped right in no prob, some problems with the fan shroud bolts but they were just tight going in. no visible leaks or anything that day or friday level went up and down but that has stopped since no more air in it. no my problem went to work and on my break around 9 was showing someone the new radiator and noticed a small drop on the bottom of the radiator near the bottom hose looked some more and found a small collection in the bottom of the fan shroud. looked forever and finally found two spots on the outside edge on both sides right inside of the fin area at the top, but it doesn't look like it's coming from that spot on either side. read alot about these and everything sounded good but did i get a bad one? has anyone else got a bad one?
GreenTJ420 is offline   Reply With Quote
Glock Forum
