Braking after putting JK Wheels on a TJ - JeepForum.com
post #1 of 5 Old 05-10-2013, 08:39 AM Thread Starter
mtdodson
I recently put 17inch Rubicon JK wheels on my 97 TJ - factory BF Goodrich Mud Terrain with very little wear. I used the SpiderTrax spacers.
Jeep rides nice and brakes smoothly at highway speeds, but braking gets rough from 15mph or so down to 0. Pedal doesn't pulsate, but it's loud and not smooth, and the front of the Jeep and maybe the tires feel to have some vibration in them. It's not like any braking issue I've encountered before. My wife said it sounds a little like a jet engine when stopping. It's only that last little bit of slowdown from around 15mph or so when coming to a stop.
Any ideas/suggestions to troubleshoot? Are these wheels/tires too much mass & weight for stock TJ brakes?
Thanks,
Mark
mtdodson is offline
post #2 of 5 Old 05-10-2013, 11:27 AM
bgredjeep
1987 YJ Wrangler
Did you go from street tires to the rubicon mud tires? Have you ever driven on mud tires before? Maybe a video with the sound would help, but I suspect you are just hearing tire noise as replacing tires and wheels shouldn't have any effect on the brakes. Worst case you might see a slightly longer stopping distance related to the larger tires, but no different noises from the brakes.
bgredjeep is offline
post #3 of 5 Old 05-11-2013, 09:23 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to TJ Forum since this question is TJ specific.
Wheelin98TJ is offline
post #4 of 5 Old 05-11-2013, 09:44 AM
Imped
Imped's Avatar
It's the tires. Perfectly normal.
OlllllllO
IndyORV
Imped is offline
post #5 of 5 Old 05-12-2013, 02:29 PM Thread Starter
mtdodson
Thanks for your feedback guys. That's probably it, and good to hear.
In the past, I've run BF Goodrich AT and the Goodyear Wrangler GS/As. The noise was the tires for sure. It's the feel of the braking that made me apprehensive. It's not as smooth as I'm used to. It's a little like the feeling you'd get from rotors that need to be turned, but not quite the same. Almost like I can feel the mass of the larger wheels and tires through the brakes, but only getting that feeling at slow speeds (from 15-20mph down to 0). Something I've never felt in braking either Wrangler I've owned.
Really appreciate both of your responses.
mtdodson is offline
