Quantcast The brakes on my 06 unlimited suck way worse than my old 02 TJ brakes - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > The brakes on my 06 unlimited suck way worse than my old 02 TJ brakes
Old 12-03-2009, 09:22 AM   #1
jgorm
Not sure why yet, but i hit the floor when checking them, and that's never good! The pedal feels much softer too. My old TJ stopped way better on 33s than my 06 does on 31s. It never even came close to hitting the floor during tons of brake tests. Granted the unlimited weighs a little more, but not that much more! Is there any difference in the brakes systems between the 02 and 06? I'm going to do a full overhaul, fluid, pads, and rotors.
jgorm is offline   Reply With Quote
Old 12-03-2009, 09:31 AM   #2
mdm
Farm Wheeler
Low fluid?
Air in the lines?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Old 12-03-2009, 09:38 AM   #3
Unlimited04
Unlimited04's Avatar
the LJs all have rear discs, whereas your 02 probably had rear drums. thats about the only difference.
The brakes on the LJ's just suck bad, even with EBC/Centric's, my brakes leave a lot to be desired on 31s. My mom's 06 LJ is the same way, but it does brake slightly better than mine (30s, no armor, bone stock).
You can change out the fluid to DOT4 to try to get all the moisture out of the current fluid, but honestly I think the LJ's should have had 2-piston calipers in front from the factory.
Unlimited04 is offline   Reply With Quote
Old 12-03-2009, 10:00 AM   #4
jgorm
Originally Posted by mdm View Post
Low fluid?
Air in the lines?
Fluid level is fine, but maybe there is air in the lines.
I did the disk swap on my 02 so that is the same. I think dot 4 is way overkill on a jeep. I don't see any way that fluid temps would get high enough to use dot 4. From what i remember dot 4 is more hydroscopic than dot 3 and needs to be changed more. I do run dot 4 in my mustang.
Old 12-03-2009, 10:02 AM   #5
mrblaine
Brake Wizard
mrblaine's Avatar
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is online now   Reply With Quote
Old 12-03-2009, 10:03 AM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Pads are wore out?
TheBoogieman is offline   Reply With Quote
Old 12-03-2009, 10:07 AM   #7
jgorm
laugh all you want! This goes to show you that not all TJ brake systems are created equal and when you are freaking out on how someone can run 35s without your $$ vanco system, this is why.
Pads are wore out?
No, but how would that cause a decrease in performance unless they were totally worn down to metal.
Old 12-03-2009, 10:16 AM   #8
Unlimited04
DOT4 is absorbs moisture more slowly with a higher initial boiling point. However DOT4 suffers a larger drop in boiling point as it accumates moisture than DOT3.
Source: Why Change Brake Fluid
I used DOT3 because I was cheap and its dry out here
Old 12-03-2009, 10:29 AM   #9
jgorm
thanks! I knew dot4 had to be changed more. There is no reason to ever want to run dot 4 in a jeep. Why would you ever get the brake fluid that hot? Reminds me of that guy that posted that he needed new brakes to drive down steep hills in neutral!
Old 12-03-2009, 10:30 AM   #10
jondotcom
My brakes also felt weak on my LJ, so I bled them out completely with dot4 and put the cheapest semi-metallic pads I could find on (from what I understand the semi-mettallic make more dust but have more bite than organic and ceramic).
The brakes are much better and I actually discovered in a panic situation I can lock up my 32s on the freeway! The only thing I still notice is that they still take much more pedal pressure to have the same result as my other vehicles, meaning they stop fine, but you have to mash the pedal harder.
jondotcom is offline   Reply With Quote
Old 12-03-2009, 10:31 AM   #11
TheBoogieman
Demonic Jeep Freak!
When mine are worn down to the point of replacing them,the pedal goes way down because the fluid level is down.I have the opposite problem.My 03 with 35's stops better than my 98' did with 31's.Go figure.
Old 12-03-2009, 10:32 AM   #12
mdm
Farm Wheeler
Glazed pads and/or rotors
Grease or oil on the rotors
Old 12-03-2009, 10:36 AM   #13
jgorm
wouldn't the fluid only go down in the reservoir? How you that effect pedal position?
Old 12-03-2009, 10:38 AM   #14
mrblaine
Brake Wizard
mrblaine's Avatar
Alright, here's why I was laughing. First off, there is no such word as hydroscopic when it comes to water absorption and brake fluid.
Dot 4 is not overkill when you consider that the master cylinder resides in one of the areas of the highest heat accumulation under the hood of a TJ and is very susceptible to vapor lock.
The higher initial dry boiling point and the fact that we can and quite often do drive to much higher elevations where boiling points are reduced makes it a worthwhile investment.
I also well understand that some rigs do have decent brakes, some don't and now you understand it as well. It's purely a function of the rig and there is no across the board answer as to why some do and some don't.
As far as the differences, the combo valve is slightly different and I'm guessing it is to bring in more rear bias due to the longer wheelbase.
The brake lines are black and more corrosion resistant and at some point they switched from a double flare to a metric bubble flare at least at the combo valve, but not at the master. The master is still the same as is the booster.
I worked on an Unlimited with bad brakes and swapped out the combo valve, master, booster, and all the pads, calipers, discs and hardware and never got it much better than it was and only after swapping on one of Van's kits could we get it to lock up 35's.
One item of note was that it responded much better to swapping in EBC green pads in the rear than any rig I've messed with.
I am Savvy
Old 12-03-2009, 10:41 AM   #15
mrblaine
Brake Wizard
mrblaine's Avatar
It doesn't with rear discs, only drums. As the shoes wear with drums, the friction surface is farther away from the drum and the take up springs retract them back to the anchor point. As you apply the pedal, you don't start building resistance in the pedal and system pressure until they contact.
I am Savvy
Glock Forum
