Brakes heating up with whistle sound - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Brakes heating up with whistle sound
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipSome Free shipping Coupon codes
Unread 12-26-2014, 06:05 PM   #1
jayfrem
Hi
I am running 36.5" IROKS bias tyres on stock brakes on my 2006 LJ ( manual ).
When going downhills it seems my brakes are heating up and emitting a " whistle" noise than comes louder as speed increase.
Is this whistle noise from tyres heating up?
Would changing brake fluid helps avoid over heating ?
Jay Frem
2006 LJ Rubicon - AEV kit, 35", Nth TT, 3"FT, PSC slides and corner crushers,AtoZ bumpers
Land Rover Disovery 1996 on 36.5" IROKS ( locked, 30 spline chromoly axles&CV's, Toy8", Warn M8274-50...)
Range Rover 1983 - mainly stock
jayfrem is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 07:01 PM   #2
biffgnar
biffgnar's Avatar
With those tires on an LJ you are well beyond operating parameters for stock brakes. Forget about band aids and properly upgrade brakes.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 12-26-2014, 08:19 PM   #3
frenchy206
Check out black magic brakes. Blaine on here makes some quality products. I would not be running that large of a tire without a big brake upgrade.
03 TJ Rubicon
frenchy206 is online now   Reply With Quote Quick reply to this message
Unread 12-27-2014, 01:27 AM   #4
jayfrem
How often should brake fluid be changed ?
What brake upgrades should i consider ?
Jay Frem
Unread 12-27-2014, 06:40 AM   #5
GringoLoco
Your best option for brakes is the Vanco big brake kit that Savvy/Black Magic Brakes sells. As for fluid, if you can't remember when it was last changed it's time to change it. Honestly I'm not sure if there's a concensus on that, I've heard once a year but don't know if that was overly cautious. I know I'm overdue.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
Unread 12-30-2014, 01:29 PM   #6
jayfrem
Will slotted disk rotors " vented rotors" help reduce over heating while keeping stock brake cylinders/pads ?
Jay Frem
Unread 12-30-2014, 01:33 PM   #7
biffgnar
biffgnar's Avatar
With tires that big on an LJ you need larger multi-piston calipers and better compound pads. Vented rotors would be a band aid that would provide little, if any, improvement.
Unread 12-30-2014, 02:14 PM   #8
JeeperLink
2001 Wrangler SE 2.5L
I agree with members advising you to upgrade your brakes. This is a safety feature and you are putting your own life and the lives of people on the road with you, in danger.
JeeperLink is offline   Reply With Quote Quick reply to this message
Unread 12-30-2014, 02:22 PM   #9
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2. even 31s push the limits of the LJ's stock brakes...despite upgraded pads & rotors.
with 36" bias IROKs, you're well into territory requiring the Vanco/Black Magic 17" kit w/ dual piston 54mm calipers...
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 03:41 PM   #10
jayfrem
Originally Posted by Unlimited04
x2. even 31s push the limits of the LJ's stock brakes...despite upgraded pads & rotors. with 36" bias IROKs, you're well into territory requiring the Vanco/Black Magic 17" kit w/ dual piston 54mm calipers...
Would I be able to retain my 15 " allied beadlocks ?
Jay Frem
Unread 02-12-2015, 12:43 AM   #11
DoomsdayTJ
No, the kit is designed for 17" wheels or larger.
DoomsdayTJ is offline   Reply With Quote Quick reply to this message
