04-25-2006, 11:53 AM
#1
Brakes Chirp when Releasing
After stopping at a stop sign or something, my '05 TJ usually makes a very soft chirp or squeek when I release the brake (just after stopping or slowing down significantly). It seems to come from the passenger side wheel, but I haven't checked with two people. Is this normal? Is there something I should grease? I guess I could call the dealership, but seems like the same ratio of problem  ain as it would be for a lightbulb or something.
Thanks... just don't know as much as I should yet.
04-25-2006, 12:03 PM
#2
I hear the same thing. I did not realize it was the brakes.
[COLOR="Black"][B]"Poor planning on your part does not make an emergency on my part."[/B][/COLOR]
[COLOR="Orange"][B]U.S.C.G. Jeep Club member[/B][/COLOR] #2
04-25-2006, 12:14 PM
#3
I get the same thing too. Its been going on for a while. The brakes work fine, have plenty of life left, so I havnt been too worried. I'll probably look into it more when I replace the pads.
2001 TJ 60th Anniversary Ed.
Cragar 342 series steel wheels
31" BFG A/T's
SkyJacker Hydro's
Olympic Grill Guard
Tuffy Glovebox
POLISH JEEP OWNERS CLUB #5
Parrothead Jeepers union member #11
04-25-2006, 12:19 PM
#4
Sounds like the caliper may be sticking a little.
05' Rubicon Unlimited, 33" BFG M/T's
[CENTER][SIZE="5"][COLOR="DarkRed"]SAW 'EM OFF![/COLOR][/SIZE][/CENTER]
04-25-2006, 12:20 PM
#5
I thought mine came from the pedal....i can sit with vehicle on and go "chirp, chirp, chirp...."
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
04-25-2006, 12:26 PM
#6
yea mine do it too, sounds like a squeak/chirp.... coming from the pedal? i had my system bled and refilled so most if not all the air is out- thats the only thing i could think of.
2007.5 WK Laredo 4.7
Lifted and Stuff
04-25-2006, 01:04 PM
#7
pedal
It could easily be coming from the pedal, I just haven't found out where, or decided if I should.
04-25-2006, 01:17 PM
#8
I have the same thing. I've replaced the brakes and lubed the calipers and it isn't coming from there. Maybe the shoes.
I'm not sure where in the pedal it could be coming from, as the noise is something on the outside.
Tom
04-25-2006, 02:24 PM
#9
We have the same squeek. As far as I can dertermine, it's coming from the right rear brake drum. On an old Jetta, we had the same noise after I did some brake work. It turned out that I had cleaned everything up so well that when the shoes retracted, the side of the metal plate they were attached to rubbed the axle side of the assembly, and i had clened up all the lubricants in that area. I put a VERY tiny bit of axle grease back on that edge and it cleared it up. I have a strong suspicion that that is very similar to the what's causing the sound from the TJ. I just have't been motivated enough yet to pull the drum aprt and investigate yet.
gritz
Patriot Blue 2000 Sport
2" REBB, JKS Quicker Disco's
4.0 w/5-Spd
dual tops
Colorado Jeep Club Member #102
"It is believed dinosaurs are extinct due to a giant meteor. That's true if you want to call Chuck Norris a giant meteor."
04-25-2006, 02:27 PM
#10
Does it happen during breaking or just when you release the pedal?
Mine were chirping when I released the pedal and found out it was a cable inside one of the drums that connects to the star adjuster for my parking breaks. I still had parking breaks and normal breaks but they were not as firm as they are now with that cable reseated.
Jim
04-25-2006, 02:44 PM
#11
mine only happens on release
31" BFG A/T's
SkyJacker Hydro's
Olympic Grill Guard
Tuffy Glovebox
04-25-2006, 05:04 PM
#12
i had the exact same problem with my 04 and took it back to the stealership.. they told me they will have to charge me to get the brakes inspected and cleaned since most brake components are not under warranty... after arguing with them for a while, i told them i will pay the 20$ as long as they get the noise gone and of course, they started to squeek only blocks after i left the dealership so i bought it back and said that's the way they are and not to worry about things... lets just say i got my money back and left a little patch of rubber so they can remember me next time by...
2004 Khaki Jeep TJ Sport
[SIZE="1"]5-Speed
32" BFG M/t's on AR-767
RE BB
JKS Discos
Mopar Grill Guard
CANADIAN JEEP OWNER
[/SIZE]
04-25-2006, 11:05 PM
#13
Yeah, mine's only on release.
04-25-2006, 11:41 PM
#14
On the release here as well....didnt think it was this common of a problem....its a jeep thing...i guess.
04-26-2006, 06:55 AM
#15
Mine does the same thing. Come to think of it, every Chrysler vehicle I've had has had the chirp. Think of it as a cool musical instrument option!
