Quantcast Brakes brakes brakes....Whos got good brakes? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Brakes brakes brakes....Whos got good brakes?
Old 12-16-2006, 08:51 PM   #16
mrblaine
Brake Wizard
mrblaine's Avatar
Originally Posted by BillR
Thanks!
I PMd Van to be sure before I decide to order the kit.
No need to PM him. Just let him know that you have the small hub conversion and they'll machine the hole out for them. Press out your existing wheel studs and re-use them with the new rotors.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 12-16-2006, 10:04 PM   #17
Zice
Dont look at me
Zice is offline   Reply With Quote
Old 12-16-2006, 11:54 PM   #18
mrblaine
Brake Wizard
mrblaine's Avatar
Originally Posted by neZZr
They're supposed to fit the small hub conversion as is, and my rotors do not appear machined. I believe over on JU mrblaine said a kit to fit the large hub will be developed soon.
Right now there are 3 iterations of the same kit based on the 4.5 bolt circle and 15" rims.
Mid 99 and down unitbearing
Mid 99 and up unitbearing
Small hub conversion
They all share the same parts with only the spacers to put the caliper bracket in the correct plane relative to the rotor varying in height and then the correct length bolts that correspond to the various spacings.
What I actually said about the 5.5 kit is until there is enough interest expressed from committed buyers, it's not likely to happen anytime soon. It will happen, it's just not economically viable yet.
I am Savvy
Old 12-17-2006, 08:14 AM   #19
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Ok. So those spacers between the knuckle and the caliper bracket are how you dealt with the height difference rather than spacers under the rotor that I saw mentioned previously?
I need a 35" tire for spare. PM me if you have something.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Old 12-17-2006, 09:51 AM   #20
mrblaine
Brake Wizard
mrblaine's Avatar
Yep, much better solution. We had to go back to the drawing board for a minute and start with the unitbearing that had the shallowest depth and machine all the knuckles to that height. Then it was just a matter of varying the the spacer height to put the caliper bracket where it needs to be.
I am Savvy
Old 12-17-2006, 10:15 AM   #21
jeepster93
jeepster93's Avatar
I have these on my '93
Off a ford, cost $18 for the brakes and like $40 for the brake mounts, etc.
They work GREAT on trail, on pavement, I really don't notice it so much.
Yes...I know they are blue...
jeepster93 is offline   Reply With Quote
Glock Forum
