Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > TJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 12-16-2006, 03:20 PM   #1
Tacoma750
Brakes brakes brakes....Whos got good brakes?
Well im running 4:88s front and rear with an aussie locker up front and detroit in the back. My driveline isnt the problem here..Im looking to go up to 34 LTBs and I want a better brake. I ahve the stock drums and that have a hard time stopping my 32 inch TSLs. I guess my cragar streetlocks dont help? What can I do to give me more stopping power? *enter JERRY*
Tacoma750 is offline   Reply With Quote
Old 12-16-2006, 03:21 PM   #2
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Send a message via AIM to neZZr
I haven't installed them yet, but I just got the Vanco upgrade kit http://www.vancopbs.com/product_p/dkj1000.htm
From what I've seen it's the only decent way to dramatically improve braking.
My Hummer Hole video
SIRA 4x4 club
neZZr is offline   Reply With Quote
Old 12-16-2006, 03:31 PM   #3
Tacoma750
also $800. I'll just get some good carbon/metalic pads I guess and maybe some bigger calipers, i dunno
Old 12-16-2006, 03:37 PM   #4
neZZr
neZZr's Avatar
I'm not sure where you will find larger calipers to fit the stock knuckles... which is why this kit was developed.
The kit uses a larger rotor and a larger, dual piston caliper. Another big factor with the TJs front brakes is that the pads ride on the soft metal of the knuckle, and will wear a divot causing the pads to get hung up... so they don't hit the rotor square. This kit solves that problem using replaceable stainless steel sliders.
The main source of cost is the machining done to the knuckles, after you buy the kit, they are no more expensive to service that the factory brakes. You can also sell your factory calipers and maybe even the pads & rotors to possibly recoup some of the original cost.
SIRA 4x4 club
Old 12-16-2006, 03:38 PM   #5
Tacoma750
Yea i understand, and its a great kit! bot not for me. Im a college kid with two modded vehichles, and dont have $800 for brakes on the jeep. I'll just do some smaller stuff to help out a little.
Old 12-16-2006, 03:41 PM   #6
neZZr
neZZr's Avatar
Just trying to help keep you from wasting money on stuff that isn't likely to help, when you could instead do a worthwhile upgrade. It's no more expensive than your 4.88 swap. If you can afford that and 34" tires, then you can afford a sorely needed brake/safety upgrade if you plan to drive it on the street.
SIRA 4x4 club
Old 12-16-2006, 03:42 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Short of mrblaine's and Vanco's (a joint collaboration product) dual piston brake upgrade like I wrote up at http://www.jeepforum.com/reviews/showproduct.php?product=152&cat=54 there isn't much you can do that will make a real noticeable improvement. The best that most of us can agree on that helps a tad would be the use of Performance Friction carbon metallic brake pads. They make a noticeable improvement but it's still not enough for 35" tires. I ran them for years but never felt I had adequate braking until I installed that Vanco upgrade I discussed in my review of that product.
See the Geezer Jeep at http://members.cox.net/jerrypb/
Getting Savvy...
Jerry Bransford is offline   Reply With Quote
Old 12-16-2006, 03:47 PM   #8
Red_
Send a message via MSN to Red_ Send a message via Yahoo to Red_
Will Vanco's big brake kit work with the stock Canyons? Or are aftermarket wheels required?
Red_ is offline   Reply With Quote
Old 12-16-2006, 03:47 PM   #9
Tacoma750
yea, its deffinatley something I NEED...but I just put a lot of money into my car. Can you say Big turbo? so money for brakes in the jeep is out...Its seeing more trail time anyway for now. Eventually i will get that kit!
Old 12-16-2006, 03:48 PM   #10
Jerry Bransford
No problem with stock wheels.
Getting Savvy...
Old 12-16-2006, 03:48 PM   #11
neZZr
neZZr's Avatar
I believe that they do... but you might want to email Vanco to be sure.
SIRA 4x4 club
Old 12-16-2006, 05:21 PM   #12
BillR
BillR's Avatar
Send a message via MSN to BillR
Can the rotors in Van's kit be ordered to fit the Warn hub conversion?
'01 TJ Sport, auto, Clayton long arms, Atlas, Detroit, OX, 35s
Yellow Jeep Club #2001
BillR is online now   Reply With Quote
Old 12-16-2006, 05:28 PM   #13
Jerry Bransford
They fit over my Warn hub conversion but my Vanco kit was a prototype. Since many of those who install this kit already have Warn hubs, I'd bet they come with the center hole machined big enough already.
Getting Savvy...
Old 12-16-2006, 05:34 PM   #14
BillR
BillR's Avatar
Thanks!
I PMd Van to be sure before I decide to order the kit.
Old 12-16-2006, 07:29 PM   #15
neZZr
neZZr's Avatar
They're supposed to fit the small hub conversion as is, and my rotors do not appear machined. I believe over on JU mrblaine said a kit to fit the large hub will be developed soon.
SIRA 4x4 club
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Technical Forum 13 12-31-2009 04:39 PM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Technical Forum 18 12-30-2009 07:55 PM
The brakes on my 06 unlimited suck way worse than my old 02 TJ brakes jgorm TJ Technical Forum 27 12-03-2009 05:08 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Technical Forum 4 05-15-2008 06:16 PM
The time now is 07:42 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
