Brakes/Bearings question, help!? - JeepForum.com
post #1 of 4 Old 11-22-2010, 09:29 AM Thread Starter
dustinsspace
So i recently upgraded from 31's which measure 29" to true 33 MT's which measure 33's on my 97 Sahara. Problem is as soon as i drove out of the shop after mount and balancing the new tires a screaching noise was coming from the front left brake dust cover. I pulled over and bent it back some and was fine until a few days later and now whenever stopping or starting from a stop, usually under 15 MPH i feel a grabbing feel in the gas or brake pedal. feels like as the rotors turn it is grabbing the brake pad or something. At higher speeds this dissappears. I just replaced the rotos and pads two days ago and it didnt fix the problem. Please help with suggestions on what to do? could this be a wheel bearing problem, i have limited mchanical knowledgea and dont know much past rotors and pads.
dustinsspace is offline
post #2 of 4 Old 11-22-2010, 03:37 PM
Kiwi_TJ
More than likley the piston on the brake calliper has become stuck in the bore, it is a common Jeep problem.
Easily fixed, remove the calliper, pull the piston out and use some emery cloth to sand the rust off the outside of the bore, between the hydraulic seal and the boot. Clean with brake cleaner and reassemble. You may need a new seal kit, I did as I knackered the seals removing them.
Hope that helps
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #3 of 4 Old 11-22-2010, 04:30 PM
chaddo78
Hey man I had the same issue after replacing pads/ rotors it was a stuck caliper got new ones today, fixed problem i guess they stick when you disturb them. Check your brake hoses as they may have caused the caliper failure. It drove me crazy for a month with the noise I hope this is a fix! Happy Jeeping!
chaddo78 is offline
post #4 of 4 Old 11-23-2010, 03:44 AM Thread Starter
dustinsspace
Hey thx for the great advice I didnt even now that could happen, and I defanately didnt realize the calipers were only $20 from the parts store. Guess i figured they be alot more expensive because of how bulky they are. Im going to pick some new ones up asap, check the lines and put em on this weekend, thx again!!
brakes , help needed , u joint , wheel bearing
front axle hub bearings question. need help thickone TJ Wrangler Technical Forum 2 10-01-2010 06:53 AM
NAsty squeek from front axle. Bearings or something in brakes???? crazyquadder YJ Wrangler Technical Forum 8 04-22-2010 08:39 AM
Brakes and Wheel Bearings DTSMA68 YJ Wrangler Technical Forum 4 05-07-2009 02:23 PM
Question about unit bearings gibbyfxdwg TJ Wrangler Technical Forum 2 06-21-2006 10:37 AM
'87 Rear wheel bearings question 4t64rd YJ Wrangler Technical Forum 2 09-14-2005 06:16 PM
