Brakes - JeepForum.com
post #1 of 7 Old 07-28-2008, 03:44 PM Thread Starter
TJ Tod
Brakes
My TJ ('99 Sport, 6 cyl. auto) has been sitting for the last month. I decided I would run it to work to keep it exercised. All is well except...the brakes are spongy and pulsate under my foot. I am mechanically challenged, so thought I would consult the experts before I take it to the shop and they try to tell me she requires a complete drive train replacement
Appreciate any advice.
TJ Tod is offline
post #2 of 7 Old 07-28-2008, 04:08 PM
JBTJ
May have some air in the line and just need to bleed out. Just an idea.
JBTJ is offline
post #3 of 7 Old 07-28-2008, 04:17 PM Thread Starter
TJ Tod
additional question
Thanks John for the reply.
I see you have a 2 inch lift and 31s. That is going to be my fall project.
Any suggestions or feedback?
Any driving issues from the lift?
Any rubbing from the tires?
Would you still go with that set up if you did it again?
Thanks,
Tod
TJ Tod is offline
post #4 of 7 Old 07-28-2008, 04:30 PM
JBTJ
Thanks,
Tod
It’s a ProComp lift. The shocks are a little stiff. But it drives just as good as stock if not better. It’s been on there for 7 years and 80k miles with not one problem. No rubbing with the tires but you need to be sure your rims have the proper backspacing. Can’t remember how much it is. Yes, I would do it again but maybe use different shocks though. Overall, I like it very much.
JBTJ is offline
post #5 of 7 Old 07-28-2008, 04:50 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
If it's pulsating, I'd check those rotors to see if there warped!
GOLENJEEPTJ is offline
post #6 of 7 Old 07-28-2008, 04:52 PM
GOLENJEEPTJ
You could also check out the rear drums too! They could be out of round!?
post #7 of 7 Old 07-29-2008, 08:04 AM
Pillswoj
As it had been sitting a month it could be a rust build up on the rotors and drums, if so a couple of days driving could smooth them back out.
Friends don't let Friends run Bosch
Pillswoj is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
