Brake Warning Light - JeepForum.com
 4Likes
  • 2 Post By WmGardner
  • 1 Post By TJ4Jim
  • 1 Post By NotURMailman
post #1 of 9 Old 06-19-2017, 03:03 PM Thread Starter
WmGardner
WmGardner's Avatar
Brake Warning Light
Brake warning light came on in my TJ yesterday. Have not been driving it much for the past couple of months. Yesterday I pulled it out, installed the Tuffy under seat box, and then started to park it again when I saw the light staying on. I moved the parking brake lever a few times, setting it, releasing it, etc. The Jeep seems to roll OK, at least for the couple of feet I tried to push it.....
So, the parking brake (obviously) will make the light/alarm activate. What else trips this light/alarm? Low pressure? (Peddle felt OK but didn't want to head out on road 'till I was more sure) Bad booster? Low fluid?
Thanks, in advance, guys.
Sent from my iPhone using Tapatalk
Happy Jeeping!
Bill
-'01 TJ ("play" Jeep)
-'06 LJ (daily driver)
Don't piss me off or I will swear at you using the most offensive 4-letter-word that I know....... TORX!!!!
WmGardner is offline
post #2 of 9 Old 06-19-2017, 03:05 PM
biffgnar
biffgnar's Avatar
I thought light came on when system felt imbalance between front and rear fluid system and that directly the mechanical parking brake shouldn't affect it. Now I suppose the parking locking up the rear does change the pressure felt in the rest of the system.
biffgnar is online now
post #3 of 9 Old 06-19-2017, 03:11 PM
tworley
tworley's Avatar
I know some people have fixed it by mashing the pedal to the floor a couple times. Mine came on after an axle swap, I pulled the combo valve (maybe proportioning valve?) and worked the plunger back and forth, that solved my warning light.
Colorado Member 307
tworley is offline
post #4 of 9 Old 06-19-2017, 03:15 PM Thread Starter
WmGardner
WmGardner's Avatar
Brake Warning Light
What?????
Honey...... The guys say I need new axles to make this problem go away......
tworley and DylanC7410 like this.
Happy Jeeping!
Bill
post #5 of 9 Old 06-19-2017, 03:15 PM
TJ4Jim
I would start by checking the fluid level in the master cylinder and if it's low look around the rear brake drums for a leaky cylinder and inspect the brake line hoses.
overlandtjm100 likes this.
If you come to a fork in the road take it.
TJ4Jim is offline
post #6 of 9 Old 06-19-2017, 03:18 PM Thread Starter
WmGardner
WmGardner's Avatar
Yeah, that is where I plan to start. It was raining like hell at the time. I was frustrated enough to be rolling it by hand, I wasn't going to stand there and let rain run down my back as I was checking fluid.
Hopefully this is all it is, low fluid and an easy leak.
Happy Jeeping!
Bill
post #7 of 9 Old 06-19-2017, 05:07 PM
2jhanna
If the fluid is low, it may not be a leak. Could be over worn pads/shoes, causing calipers/wheel cylinders to be full of fluid.
jhanna
denton county, tx
2jhanna is offline
post #8 of 9 Old 06-20-2017, 10:40 AM
NotURMailman
NotURMailman's Avatar
Things that will turn on that light:
parking brake on
fluid in master cylinder low
high pressure differential between front and rear brake circuits
WmGardner likes this.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #9 of 9 Old 06-21-2017, 01:57 AM
Jonny Jeep
Jonny Jeep's Avatar
There's no low brake fluid sensor on TJs.
Sent from my D5803 using JeepForum
Jonny Jeep is offline
