Brake Pedal is stuck upward - JeepForum.com
post #1 of 7 Old 10-16-2014, 02:57 PM Thread Starter
KP-J33PIN
Started the jeep this morning and noticed a pop and vibration happening afterward. Turned the jeep off let it rest for a min then fired back up and the vibration was gone hasn't come back since.
Noticed though the brake Pedal is stuck upward can only push it down about a 1/4 of the way with minimal braking power being supplied when moving. Brakes aren't constricting movement when rolling in neutral. Even when jeeps parked and off the brake pedal is stiff as a board. Wondering if anyone has had this issue, i think it might be the master Cylinder or Brake Booster. Or maybe the lines just need rebleeding Any feedback could really help me narrow down this problem.
-KP
" Why are you so sweaty?!?!"
" I was watching cops"
KP-J33PIN is offline
post #2 of 7 Old 10-16-2014, 03:31 PM
Jeepsr4me
Check the hose to the booster.
Jeepsr4me is offline
post #3 of 7 Old 10-16-2014, 03:56 PM Thread Starter
KP-J33PIN
Already have, no cracks in the hose. Checked the checkvalve also
post #4 of 7 Old 10-16-2014, 04:04 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Is the booster holding vacuum?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 7 Old 10-16-2014, 04:24 PM Thread Starter
KP-J33PIN
The booster seemed to have pressure because when we loosened a line off the proportioning valve with foot on pedal it would decrease to the floor. Tighten the valve and fire the jeep back up and the brake pedal was back to the top and stiff as a board
post #6 of 7 Old 10-16-2014, 04:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
No, booster does not have pressure. It is purely a vacuum assist device.
Opening a line removes the need for assist because it is just a big leak at that point with no need for the assist from the booster.
Check the booster and see if it is holding vacuum.
I am Savvy
mrblaine is offline
post #7 of 7 Old 10-16-2014, 04:56 PM Thread Starter
KP-J33PIN
would hand over check valve indicate pressure?
