Quantcast Brake Pads And Rotors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Brake Pads And Rotors
Free Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.com
Old 07-20-2004, 08:32 AM   #1
WR4NGLER
The stealership told me to replace my pads and rotors it's 450 dollars. I told them not to do it.
They told me the pads need replaced and the rotors are a bit rusted (not warped) so they need replaced too.
How much are pads and rotors (assuming I take them somewhere and they can't be cut), so that I can do the overhaul myself.
WR4NGLER is offline   Reply With Quote
Old 07-20-2004, 08:49 AM   #2
wyldejackyl
rust hurts nothing. Measure them and cut them if they are in spec.
NEVER get your jeep serviced at a dealer. Would you want your teeth worked on by a 8th grade biology student? That's how the mechanics are at the dealer.
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline   Reply With Quote
Old 07-20-2004, 08:55 AM   #3
WR4NGLER
I just needed to know what was wrong first before I did anything. I'm not super-jeep guy, so I'm still hesitant to work on some things. I plan on getting some nice rotors and pads and doing it myself, I just needed a double-take on it.
(an 8th grade teacher is better than what I can do for most stuff)
Old 07-20-2004, 10:27 AM   #4
chevtech
Doh!
Ex-dealer mechanic thinking this may not be an entirely accurate statement.
chevtech is offline   Reply With Quote
Old 07-20-2004, 10:49 AM   #5
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Rust on cast rotors is normal, I almost can't believe that dealer mechanic said they need replacing because they are "a little rusted". Brake pads sell for $30 or so and it takes maybe an hour to replace both sides with no special tools needed.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 07-20-2004, 10:56 AM   #6
WR4NGLER
Jerry, I made sure to ask him if they were warped, and he said no.
Maybe they have a metal glaze on them, as frequent commuting puts more than normal stress on my brakes, and because he said they can't turn them they need replacing?
Would you suggest replacing the pads first, and based on results determine if new rotors are needed?
Old 07-20-2004, 10:58 AM   #7
WR4NGLER
The Jeep is at the dealer now, and I paid $40 to diagnose it, so when I pick it up I can ask more questions (since I paid to get the problem diagnosed). I will ask specifically why they think it needs replacing and that I heard non-warped rotors should be fine.
Who knows, they might have just been trying to screw me over.
Old 07-20-2004, 10:59 AM   #8
chevtech
Light rust pitting is pretty common in rotors. Thing is though, the rust will imbed itself in the pads and can cause squeaky brakes. If it is just light pitting I would just have them resurfaced. If the pitting is severe and you can see it only gets worse as you cut into the rotor (sometimes they do that, rusting from the inside) than you may consider just replacing them.
Old 07-20-2004, 11:01 AM   #9
cravnpup
You can get performance rotors and pads for $250 shipped... Do not get Chrysler replacement parts!! They will warp in no time.. BTW, it's not necessarily the mechanics that are bad, it's the Service Managers and the parts they have to work with that should steer you away.. Most service managers are told to do the most profitable repair, not the easiest or cheapest. That means replacing bad parts with an OEM part that's double the aftermarket price and half the aftermarket quality... If you can start doing your own work, I'd highly recommend it. Start small and work your way up as your confidence grows. You'll save a ton of money, and you'll be learning a valueable tool that can be used for the rest of your life..
2000 Z71 Tahoe (mine) - Magnaflow, UPD, ASP, CFM-Tech, Superchips, Transgo, BFG, JBL, JL Audio
2002 TJ-X (hers) - 4.0, 5 speed, 3.73's (open), 2" BB with 32" BFG AT's on AR23's, Turbo City intake, 180* t-stat with highflow housing, and a Magnaflow 14" catback with straight pipe (can you say loud?)..
cravnpup is offline   Reply With Quote
Old 07-20-2004, 11:03 AM   #10
WR4NGLER
Understood. So, I'll find a place that can turn them, and get a price and then bring them there and if they say they can't turn them because of that reason, I get new ones. If they turn them, then I cna hold off for a while. And then I can put the rotor back in and replace the pads.
Also, I have to see what the dealer says concerning his diagnosis of the problem, I'll ask him to be more specific.
Old 07-20-2004, 11:32 AM   #11
Jerry Bransford
Verify that the rotors are not composite before having them turned, only cast rotors do well after they're turned. Any shop that turns rotors can tell you if they're cast or composite.
Getting Savvy...
Old 07-20-2004, 11:39 AM   #12
WR4NGLER
ok.
I just got a call from the dealer, guy didn't charge me for the diagosis of the brakes and said when I pick it up he will talk to me about it.
He did, however, charge me 360 for:
Fuel Injection Servicing
Oil Change
Rear Tail Light Fix
Sway Bar Link Fix
Old 07-20-2004, 12:03 PM   #13
brrempel
Oil Change
Rear Tail Light Fix
Sway Bar Link Fix
That's a lot of $ for not much work.
Brian
brrempel is offline   Reply With Quote
Old 07-20-2004, 12:11 PM   #14
cravnpup
I hope they ok'd it with you first...
Old 07-20-2004, 12:21 PM   #15
fyrfyter43
I would have to disagree with you. Composite rotors can be resurfaced, without problems, provided that the correct adapters are used.
fyrfyter43 is offline   Reply With Quote
Glock Forum
