brake lines - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > brake lines
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 11-20-2008, 06:21 PM   #1
swampdonky
brake lines
so i got the front rough country brake lines for my jeep do i need to get the rear one too. 4 inch lift
swampdonky is offline   Reply With Quote
Unread 11-20-2008, 07:29 PM   #2
Stu Olson
Stu Olson's Avatar
Look at how your rear brake lines are routed....really take a look at them.
If you axle goes full droop for full stuff, will the break lines be stretched? If you think the answer is yes, I'll listen to your explanation as to how you think that will happen (assuming you still have the factory lines and are running stock or replacement rear upper arms).
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Unread 11-20-2008, 08:49 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What Stu is getting at is that your rear brake hose runs along the upper control arm on the driver side and attaches to the axle. Then hard lines run along the axle to the caliper or drum.
You do not need a longer brake line for a 4" lift.
Wheelin98TJ is offline   Reply With Quote
