brake line size/diameter - JeepForum.com
post #1 of 8 Old 09-20-2005, 10:19 AM Thread Starter
UCTJ
UCTJ's Avatar
Anyone know the size for the hard brake line on a rear D44 w/disc? Is it a set size or could it vary?
UCTJ is offline
post #2 of 8 Old 09-20-2005, 10:21 AM
RockRunner85
Its 3/16 with standard flare fittings.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #3 of 8 Old 09-20-2005, 10:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Double-flare I believe. At least that's what I found when I had to cut part of the brake line off to install the disk brake conversion, and that's the kind of flare I put into the brake line when I re-flared it. I think automotive brake lines are mostly double flared but I'm by no means a brake line expert.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is offline
post #4 of 8 Old 09-20-2005, 10:50 AM
RockRunner85
I think double flare and standard flare are the same thing. I know when we bought brake lines for my friend 8.8 swap we had the choice of standard flare or bubble flare. The bubble was not right and standard matches what was on the Jeep already.
Not sure on the terminology of brake line flares. Your probably safer saying double flare than standard.
post #5 of 8 Old 09-20-2005, 10:54 AM
RockRunner85
Okay I figured it out. Standard flare (or metric flare) is the type of nut used to hold the brake line in the fitting. Then theres double flare and bubble flare for the flaring done to the end of the brake line.
post #6 of 8 Old 09-20-2005, 10:59 AM
Jerry Bransford
Administrator
Well, standard flare and double-flare kits are different and there is an extra step in the double-flare process so they're really not the same thing. I think whether a single or double flare is used may depend on the anticipated fluid pressure or perhaps if it is a hydraulic line.
post #7 of 8 Old 09-20-2005, 11:02 AM
BEANS
BEANS's Avatar
I found this site that explains brake line flaring
http://classicbroncos.com/brake_line_flaring.shtml
2001 SPORT 4.0 AUTO EMPTY GAS TANK
2 1/2"O.M.E. 1"Body LIFT
33" DUNLAP'S
JSK QUICK DISCONNECTS THAT I'LL NEVER DISCONNECT
LIMITED SLIP WITH 4.11'S FRONT AND BACK
S.Y.E
7'6" SNOWAY POLY PLOW
Elect Radiator fan on a Delta control
Borla Header, Catback Exhaust By Volant 304SS
BEANS is offline
post #8 of 8 Old 09-20-2005, 11:27 AM Thread Starter
UCTJ
UCTJ's Avatar
Ok, so I guess I double flair it....or if somebody knows the part number for a Rubicon's brake lines both sides, I could just order some of those and they should fit w/no problem.....BTW does anyone know if e brake cables from an 8.8 will work with a D44 w/discs????
UCTJ is offline
Brake Line nut size timdastis TJ Wrangler Technical Forum 0 08-04-2009 08:14 PM
what size brake line tubing ? SteveJcoYJ YJ Wrangler Technical Forum 2 08-13-2008 07:23 AM
what size brake line do i have? eclipse27 TJ Wrangler Technical Forum 5 09-04-2007 04:04 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
Brake line wrench size Shikkapow YJ Wrangler Technical Forum 12 01-29-2007 08:18 PM
