Brake line replacement???? - JeepForum.com
post #1 of 1 Old 04-03-2013, 09:31 PM Thread Starter
wml52
I have a 2000 Wrangler that has severely corroded brake lines that need to be replaced. I was going to replace them with SS lines however all of the kits I see for replacement lines are for wranglers that do not have ABS, my wrangler originally came equipped with ABS.
My ABS system has not been used in years due to the fact that both front and rear axles have been replaced with Dane 44's and so the sensors were removed a long time ago. The ABS pump is still in line, however the system is non functional.
I would like to know what would be involved in removing the ABS pump and replacing the OEM brake lines with lines for a non ABS wrangler. What would I need as far as parts go i.e. proportioning valve and what have you?
Any help would be appreciated.
Thanks
Bill
wml52 is offline
