brake line question - JeepForum.com
post #1 of 5 Old 12-09-2006, 10:10 PM Thread Starter
scrnnmssuck
brake line question
i am about to purchase a 4" Series II Suspension Lift by rough counrty.. does anyone know if i have to buy longer brake lines or will the stock ones be good enough. does anyone also have any complaints or feed back on this lift
scrnnmssuck is offline
post #2 of 5 Old 12-10-2006, 12:54 AM
TJAB
I'm doing a 3" and have the same question.
TJAB is offline
post #3 of 5 Old 12-10-2006, 09:41 AM
yellowismellow
Custom User Title
yellowismellow's Avatar
im happy with my rough country lift. its 4 inches. if you plan on disconnecting, you'll need longer brake lines. otherwise your fine.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #4 of 5 Old 12-10-2006, 09:45 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I actually doubt you'll need longer brake lines with only 4" of suspension lift unless it has an unusually large amount of axle droop. With my very basic 5.5" RockKrawler lift, I did not need longer brake lines. It was only after I installed a 4.5" long arm Rubicon Express kit with flexier trackbars, longer shocks, flexier drag link, etc. that longer front brake lines were required. So it's more the lift itself, not just its height that determines when longer brake lines are required.
Jerry Bransford is online now
post #5 of 5 Old 12-10-2006, 10:47 AM
igofshn
Locked @ both ends
igofshn's Avatar
go get front brake lines from a 95 wrangler. They are longer than tj brake lines and work perfect. Cost less than $20 each and bolt right up.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
brake line question 05RedRME TJ Wrangler Technical Forum 5 01-27-2008 08:09 PM
Brake line question JeepPirate TJ Wrangler Technical Forum 3 06-11-2007 07:06 PM
Brake line and E-brake Question vdubstreets YJ Wrangler Technical Forum 43 12-28-2005 07:02 AM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 02:25 PM
Brake line question Kump33 TJ Wrangler Technical Forum 6 04-29-2005 10:49 AM
