Brake lights,turn signals,hazards Not working - JeepForum.com
post #1 of 11 Old 07-05-2010, 02:13 PM Thread Starter
95cherokeeSE
2014 JK Wrangler
I have a 97 Tj and the brake lights all dont work along with the turn signals and hazards. All the fuses are fine and there is power to the fuses but not to the taillights. The park lights in the back work and so do the reverse lights but the stoplights and blinkers dont. Any ideas?
2014 Anvil JK 2-door, 6-spd, Rubicon Express BB, 265/70/16 General Grabber AT2
95cherokeeSE is offline
post #2 of 11 Old 07-05-2010, 03:28 PM
fishinjeeper
Thats weird, I would say change the fuse anyways just in case it has a small crack that you can not see.
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #3 of 11 Old 07-05-2010, 03:35 PM
Sundowner
Could be a relay, perhaps...I'm not sure what's run alongside what in a '97. Check all of your connections.
Sundowner is offline
post #4 of 11 Old 07-05-2010, 03:40 PM
wushaw
Rockin jeep
wushaw's Avatar
It ll goes through the turn signal switch, replace it and go from there.
wushaw is offline
post #5 of 11 Old 07-05-2010, 05:19 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
X 2 and very common.
http://www.jeepforum.com/forum/f11/w...7/#post6129430
TheBoogieman is offline
post #6 of 11 Old 07-05-2010, 09:23 PM Thread Starter
95cherokeeSE
2014 JK Wrangler
So even the stoplights go through the turn signnal switch?
post #7 of 11 Old 07-06-2010, 06:37 AM Thread Starter
95cherokeeSE
2014 JK Wrangler
Any ideas?
post #8 of 11 Old 07-06-2010, 11:43 AM
Jonny Jeep
Jonny Jeep's Avatar
If you want to check the switch before replacing it, and yes the stop lamps do feed through the switch, go to...
Jeep Service Manuals
Select TJ, 96/97, and Turn Signal and Hazard Warning Systems in the drop down boxes. The continuity test for the pins is on page 3.
It does appear to be the switch as the stop lamps, turn signals and hazards are on on different fuses.
Jonny Jeep is offline
post #9 of 11 Old 07-07-2010, 05:03 PM Thread Starter
95cherokeeSE
2014 JK Wrangler
Its fixed, it was the turn signal switch. Now everything works thanks for the help guys.
post #10 of 11 Old 07-07-2010, 07:38 PM
wushaw
Rockin jeep
wushaw's Avatar
Cool
wushaw is offline
post #11 of 11 Old 06-21-2011, 06:24 PM
LineGuy631
I have the same problem so i just replaced the turn signal switch thinking it would fix everything, however it did not. Any other ideas as to what it could be? A friend of mine said check the ground connections but im not sure where they are located or really what they look like.
LineGuy631 is offline
brake , light , turn signal , hazard , broke , electric , electrical , problem
brake lights, hazards and turn signals inop smitty88 TJ Wrangler Technical Forum 6 08-04-2012 04:10 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Turn Signals/Hazards Won't Work! Notrightfly TJ Wrangler Technical Forum 8 09-30-2007 08:14 PM
Sometimes turn signals don't work but hazards do? Mead TJ Wrangler Technical Forum 12 11-22-2006 08:50 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
