brake lights, ok; tail lights/side markers/turn signals not.... help?
#1 | |
i wear foil underwear too
well, i guess, title says it all...
My side markers, turn signals, and tail lights don't light up.... but my brake lights are ok. I checked the 'tail light' fuse, but it's ok. What next? Will a double filament bulb burn out one filament and cause this problem? lj
ಠ_ಠ |
#2 |
Check the bolts that hold the tail lights onto the body of the Jeep. The 2000 TJ that I just bought had the same problem, and all I did was take off the lights, clean up the bolts and the holes that they went into so that they got a better ground, and all was good.
#3 | |
Never Forget
your tail lights are on differnt fuse, check others
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
