Brake Light switch replacement/Adjustment - JeepForum.com
post #1 of 4 Old 12-30-2006, 09:31 AM Thread Starter
SublimeJeep
I need to replace/adjust my brake light switch. Anyone have any pointers?
Any help would be great.
Thanks
1998 Black Jeep Wrangler
4.5" Rubicon Express LA, 4.56s, a D44 w/a Detroit , Detriot tru-trac in the front, PSC armor and some swell other stuff that keeps me entertained.
SublimeJeep is offline
post #2 of 4 Old 12-30-2006, 10:46 AM
JFM626
JFM626's Avatar
Removal
Remove the steering column and the knee protector covers
Push down hard on the brake pedal, and at the same time turn the switch assembly counterclockwise 1/4 to 1/2 a turn and remove the switch
Remove wiring harness
Testing switch
Pull plunger all the way out
Test for continuity between two terminals nearest the plunger, none =replace switch
Push plunger all the way in
Test continuity between the two terminals furthest away from the plunger, none =replace switch
Replacing
Replacing switch is the opposite of removal but pull out the plunger all the way. Once its installed pull the brake pedal as far up as you can. You should hear that ratcheting sound as the switch adjusts itself.
JFM626 is offline
post #3 of 4 Old 12-30-2006, 04:24 PM Thread Starter
SublimeJeep
Thanks
I just finished it up a little bit ago. Didn't take much more than 45 min.
Pretty straight forward
post #4 of 4 Old 10-28-2008, 11:31 AM
4bangerWrangler
This thread helped me today. After reading this I ran to the parts store and bought a brake light switch. 20 minutes later my brake lights were working again. Thanks guys!
Colemanitis
2000 Jeep Wrangler SE
4bangerWrangler is offline
brake light switch? surfingopher TJ Wrangler Technical Forum 5 02-15-2010 08:30 AM
Where is the Brake light Switch? baothaitu YJ Wrangler Technical Forum 4 01-04-2009 05:52 PM
87-90 Brake light adjustment? vdubstreets YJ Wrangler Technical Forum 13 12-10-2007 06:36 PM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
brake light switch replacement...need help Rooster2 YJ Wrangler Technical Forum 7 12-05-2003 11:51 AM
