Brake light/signal issues - JeepForum.com
post #1 of 4 Old 03-29-2005, 07:46 AM Thread Starter
ClarkAM1
I have a 97 TJ, automatic, with 94k-miles. When right signal is used, all three break lights flash, and when the break is applied, all three break lights come on as well as the front right signal lamp. This problem started when the top was left off during an unexpected rain...interior got very wet. It has been drying for 2 weeks now, and not correcting itself...any suggestions? Thanks!
ClarkAM1 is offline
post #2 of 4 Old 03-29-2005, 07:52 AM
fergyfer
fergyfer's Avatar
It sounds like you have a grounding/shorting problem somewhere. I'd trace all the tail light wiring and make sure you don't have some bare wire grounding to the chassis or to another wire. Maybe a taped connection is holding water inside it...etc.
Green 99 Sahara
OME 2.5", JKS Discos, 31" Dayton Timberline MT's
IPF/PIAA Headlight Conversion
fergyfer is offline
post #3 of 4 Old 03-29-2005, 08:15 AM
JFM626
JFM626's Avatar
It is entirely possible that that soaking your jeep recieved, may have put some water into your turn signal switch. The current for your brake lights, initially, comes through your brake light switch, then into your steering column turn signal switch. When you apply the brakes the current flows through the brake switch then through the turn signal switch and on to the brake lights. When you turn a signal switch on the brake light circuit still flows through the switch but the signal is switched through the flasher unit on the side you have the switch turned to allowing the lights to flash. If the contacts inside the signal switch have contact to both the brake lites and the right turn, you will get exactly what is hapenning, the contacts for the right turn would be lower in the switch than the contacts for the left turn, it would not take much moisture to cause this. You might be able to use air pressure to blow out the moisture, but in the worst case you may need to replace the turn signal switch etc.
JFM626 is offline
post #4 of 4 Old 04-11-2005, 11:18 AM Thread Starter
ClarkAM1
Thanks for the info, I played with the switch, and didn't have any luck with getting it to work right. After replacing the multifunction switch (signal switch) with a new unit ($58 from dealer) it is working like a dream. Very easy to replace, by removing 8 screws and two wire harnesses! Thanks for the help!
ClarkAM1 is offline
Parking Light/Signal Issues TellyDSP YJ Wrangler Technical Forum 15 06-28-2007 07:03 AM
RT Turn Signal/Brake light tjtone TJ Wrangler Technical Forum 2 03-30-2007 12:27 PM
Turn Signal and Brake Light Jeep_Grrl TJ Wrangler Technical Forum 8 08-13-2005 03:24 PM
signal light goes on when I brake Decz TJ Wrangler Technical Forum 9 02-24-2005 06:20 AM
No Brake and signal light ayadov YJ Wrangler Technical Forum 2 05-26-2002 09:58 AM
