Brake install How-To Write up?? - JeepForum.com
post #1 of 9 Old 05-12-2005, 01:16 PM Thread Starter
bam9382
Time to do the brakes.. and seeing that its like 200 to do at a shop... i am goin to do it myself.. ive done discs before.. and for the 200 i think i will just buy a 55 buck high lift jack.. and the pads and do it myself.. i did a search and couldnt find a write up.. anyone know a good site?? also how hard is it to do the drums.. should i have a shop do the rear?
bam9382 is offline
post #2 of 9 Old 05-12-2005, 01:29 PM
Varnish
Varnish's Avatar
imho, skip the hilift and get some jackstands and a Haynes manual instead. If you don't do this too often use the clunky bottle jack that came with the jeep or purchase a low price hydraulic.
The drums aren't as fun/easy as disc brakes but can certainly be done with common hand tools and would also be covered in the Haynes manual.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #3 of 9 Old 05-12-2005, 01:32 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
x2 on not using the hi-lift.
Wheelin98TJ is online now
post #4 of 9 Old 05-12-2005, 01:38 PM
RockRunner85
x3 don't use the hilift to do your brakes
As far as drum brakes go jack up both rear tires. Take off both drums, do one side at a time and use the other side as a reference. It helps to have a brake tool to remove the spring clips holding the shoes on. After you install the new pads adjust the adjuster so there is slight drag and back it off about a turn.
Oh yeah when you go to take the drums off make sure your parking brake is off. I forgot this once on my 4runner and couldn't figure out why the damn things wouldn't come off.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #5 of 9 Old 05-12-2005, 02:10 PM
fergyfer
fergyfer's Avatar
Unless you plan to do some EXTREME rock crawling, I'd use the money to pick up a decent floor jack. I can't imagine not owning a floor jack now that I've had one for 15 years. I own a hi-lift jack too, but have never used it with my jeep.
Most importantly, do not breathe the dust from the brakes. Use a brake cleaner that will wet down and remove the dust. I've never owned a brake tool to remove springs etc. and have done many brake jobs. I probably don't know what I'm missing without one, but it can sure be done. Digital camera comes in handy when you are taking the back brakes off. If not, jack stand it up and do like the guy above said about copying the left and right with each other. Remember, they will be oposites of each other.
Green 99 Sahara
OME 2.5", JKS Discos, 31" Dayton Timberline MT's
IPF/PIAA Headlight Conversion
fergyfer is offline
post #6 of 9 Old 05-12-2005, 02:32 PM
ATL TJ
To do the fronts this is all you need:
http://www.jeepsareus.com/Merchant2/...ode=7941903638
I changed both sides out in about 40 minutes.
I haven't found a write up for the TJ brakes. But it was nearly the same process as for my Maxima and I'm sure as many other vehicles. Check out this site under "Brakes" http://www.motorvate.ca/mvp.php/300
ATL TJ is offline
post #7 of 9 Old 05-12-2005, 03:45 PM
crgrissom
Master of Reality
crgrissom's Avatar
Here are two writeups for the fronts:
http://www.stu-offroad.com/index.shtml
http://www.4x4xplor.com/disc-brakes.html
...and this for the rears (for an XJ, but should be the same)
http://jeepin.com/features/drums/index.asp
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #8 of 9 Old 05-12-2005, 04:12 PM
htownjeep
What's that noise?
htownjeep's Avatar
Jesus Christ! Don't use a Hi-Lift to do your brakes! Hope you read this before you have killed yourself!
Standard jack and jack stands would be just fine for this. Please please please please don't use the hi-lift for that. Only use it for extreme emergencies on the trail when nothing else will work!
Drink upstream from the herd.
htownjeep is offline
post #9 of 9 Old 05-13-2005, 08:43 AM
ATL TJ
Chuck
Damn, I always forget about those sites. Good info!
ATL TJ is offline
ZJ spring install write up badoosh27 TJ Wrangler Technical Forum 11 10-30-2007 06:06 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Good Write UP for RE 4.5 install? BigPeters TJ Wrangler Technical Forum 3 01-25-2006 03:33 PM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Re install tech write-ups DogHouse TJ Wrangler Technical Forum 1 04-12-2004 11:03 AM
