Brake hose install ? - JeepForum.com
post #1 of 1 Old 09-26-2011, 11:24 PM Thread Starter
risz
Just installed new stainless brake lines to my 98 TJ. While at it, upgraded brake hoses, Crown Stainless braided hoses. Installed, seemed easy enough...bled the rear lines, all fine...went to bleed the front lines and the bleeder screws were twisted and no brake fluid... even went as far as to remove bleeder screws completely...no brake fluid...master cylinder was full...checked for leaks and proper connections...not sure what I didn't do??
is it possible i have the hoses installed backwards? or missing something not thinking about??
Any help or suggestions would be great...
risz is offline
brake hose , crown automotive , install
Help with brake hose removal. purdueme06 YJ Wrangler Technical Forum 9 04-04-2010 02:18 PM
Brake Hose? dz1087 TJ Wrangler Technical Forum 11 03-31-2010 04:43 PM
Power steering hose install help garybattles TJ Wrangler Technical Forum 3 05-30-2009 07:48 PM
Removing Brake hose from Hard brake line?? chupacabrah YJ Wrangler Technical Forum 11 03-19-2007 03:29 PM
where can i get a replacement brake line (not the brake hose) cueball YJ Wrangler Technical Forum 6 06-05-2005 07:42 AM
