Brake Fluid Reservoir Cap Boot Cut - JeepForum.com
post #1 of 3 Old 04-20-2013, 02:58 PM Thread Starter
cdduffman
Hey guys,
Probably a dumb question. My brake pedal was hitting the floor, causing me to think that I needed to bleed my brakes. Well I did and as I was filling the master cylinder, I play with the rubber boot that sits inside the cap to the master cylinder. I extended the cap and realized it has a small slit in the bottom of the boot. Would this cause air to enter (cause the break system) to lose it's effectiveness?
thanks
cdduffman is offline
post #2 of 3 Old 04-20-2013, 04:59 PM
durango-bob
2006 WK
It can let moisture in which is a bad thing. You should replace it.
durango-bob is offline
post #3 of 3 Old 04-20-2013, 11:08 PM Thread Starter
cdduffman
I just went to the dealer and and purchased another cap with the boot. It has a slit in the bottom as well. I guess this is the way it is supposed to be.
bleeding , brakes , cap , master cylinder , pedal
