brake fluid disapering with no spots on the floor???? - JeepForum.com
post #1 of 6 Old 07-04-2010, 01:04 PM Thread Starter
TheSherp
I have had my break light come on 2 times in the last month, when it does the break pedel goes to the floor but I can stop very slowly. After filling the resivior and bleading the breaks its fine for a while. Now my pedle is very hard. It only moves about a half an inch then I start feeling the breaks. I've looked under the jeep and there is no leaks anywhere to be found. Anyone have an idea what could be going on? I'm at a loss. Someone said that the break booster could be leaking on the back side and sucking it into the vacume and possibly burning it off??????
TheSherp is offline
post #2 of 6 Old 07-04-2010, 01:10 PM
chainbrain2002
id check and see if you have a leak in youre rear brake cylinders, or if you are getting brake fluid sucking from your master cylinder into your brake booster through the rear seals. check your hoses for any dampness, as well as the resivior. is your jeep smoking while its running?or while you press the brake while its running?
chainbrain2002 is offline
post #3 of 6 Old 07-04-2010, 01:14 PM Thread Starter
TheSherp
When I get back from helping the GF I'll have to pull the MC and see. I'm not seeing anything at any of the wheels or anything on any of the hoses. I don't notice any smoking at all. I'll have to see if it is when I press the break.
TheSherp is offline
post #4 of 6 Old 07-04-2010, 02:51 PM
chainbrain2002
ok try this check the vaccum line from your brake booster to the intake for any fluid residue in the line, if it looks wet you may have to replace youre mc and vac booster together to fix the problem.
post #5 of 6 Old 07-04-2010, 03:10 PM
Outatime05
(Post deleted by author.)
Outatime05 is offline
post #6 of 6 Old 07-07-2010, 06:19 AM Thread Starter
TheSherp
Well I tried that last night and it all checked out good. The only other thing I can think of is its a small leak in the drums. I'll pull those again and try to see if I can find the leak. I'll also re blead the system again and see if that helps. Any other ideas????
TheSherp is offline
brake fluid , leak , brake master cylinder , brake cylinder
brake goes to the floor lynnboy021 Wrangler General Discussion 7 12-18-2009 07:31 AM
Brake pedal almost going to floor? Prryan45 TJ Wrangler Technical Forum 1 12-14-2008 07:26 PM
Leaking fluid into pasenger side floor board ntomczek TJ Wrangler Technical Forum 2 06-20-2008 12:03 PM
Brake pedal almost on the floor horseman YJ Wrangler Technical Forum 11 11-16-2007 07:54 PM
pwr steering fluid in brake fluid - how to remove? Curtis Doran TJ Wrangler Technical Forum 26 03-20-2006 01:55 PM
