Brake Booster or Master Cylinder>? - JeepForum.com
post #1 of 3 Old 03-19-2010, 08:31 PM Thread Starter
MikeUnlimited04
Ok, For the last 2 months my brake pedal has felt spongy and soft. Occasionally the pedal will lose pressure and become VERY difficult to stop. Other times it works fine. I would say 7/8 stops are fine. but the other 1/8 the pedal feels loose and will sink to the floorboard.
Today I was pulling up on a red light and went to brake and the pedal had NO pressure AT ALL. The brakes were completely ineffective. I had to downshift and yank the parking brake in order to stop.
It is time I get this taken care of before I cause a wreck. I had the brakes bled when the problem started and no air was found in the lines. This leads me to either a bad master cylinder or bad brake booster... any ideas what to look for?
thanks!
United States Air Force F-15E Strike Eagle Crew Chief
Silver JEEP Club Member #36
MikeUnlimited04 is offline
post #2 of 3 Old 03-19-2010, 08:34 PM
XTC Jpr13
XTC Jpr13's Avatar
check the vacuum line connected to the booster as well.
2010 Sponsors
XTC Jpr13 is offline
post #3 of 3 Old 03-19-2010, 08:42 PM Thread Starter
MikeUnlimited04
will do in the morning! thanks!
Master cylinder/Brake booster question Smitty1 YJ Wrangler Technical Forum 0 05-10-2009 08:32 AM
I need to replace my master cylinder & booster - Will This Work!!! mandng0 YJ Wrangler Technical Forum 23 04-01-2009 02:42 PM
Help with Brake Booster/ Master Cylinder Tompatt YJ Wrangler Technical Forum 13 10-27-2008 02:03 PM
Vanco Brake Master Cylinder/Booster goatboy YJ Wrangler Technical Forum 5 04-26-2008 10:28 AM
brake booster and master cylinder sandman'sjeep YJ Wrangler Technical Forum 3 06-28-2006 08:51 AM
