Brake block issue and Axle vent bolt length? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Brake block issue and Axle vent bolt length?
ZONE 4.25" combo lift for TJ available at Rockridge4wRough Country Lift Kits and Parts!Warrior Products @ Oconee Off-Road! 706-534-9955
Unread 10-24-2014, 08:47 PM   #1
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
I am redoing the brake lines on my 8.8 (had them jerry rigged before), I picked up the block for the rear but installing it the right way won't work as it will interfere with the track bar and gas tank. Will it hurt to flip it over?
Normal-
Reversed-
Also does anyone know if the D35 vent/block bolt is longer than the 8.8 bolt? I am only getting about 1/2 a turn of threads engaging. Or would it be OK to just grind the block down some?
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Looking to swap my 4" springs for your 2-3" springs. PM for details.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 10-26-2014, 04:19 PM   #2
oakmckinley
I can't see why it would be a problem flipping it over.
Get a junkyard bolt from another vehicle, or grab a few in different lengths. I think napa also sells bulk stuff like that.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline   Reply With Quote Quick reply to this message
