bowed or bent front coil springs - JeepForum.com
post #1 of 19 Old 07-20-2010, 11:40 PM Thread Starter
reelnative
I bought a used set of 4in lift coil springs and upon taking them out of the box I could tell they had a slight bow to them, when i layed them on the ground and rolled them I would come to a spot were 2 or 3 of the coils in the center of the spring would be about 1/2in off the ground, then roll it a bit more then both ends would be off the ground, my question is is this normal and are they still good or are these coils on there way out or just bad, thanks for all your help guys
reelnative is offline
post #2 of 19 Old 07-21-2010, 12:56 AM
asknight
My RC 2.5" coils have a curvature since they were installed new and they have 8-10k on them now and still the same curve.
asknight is offline
post #3 of 19 Old 07-21-2010, 01:40 AM
ROLLTIDEtj
I would imagine it is due to them being on a jeep that probably had a stock front sway bar on 4" of lift, and the rears are probably because the position of the stock upper coil seats.
2004 Rubicon - 4.0 - 5 speed manual - Rough Country 4" Stage II lift, RC front adjustable track bar, 2.2 shocks, 33x12.5x15 Goodyear MTR with Kevlar on Crager soft 8's, 4 Hella Black Magics, Edge Trail Jammer with Intake, JL TR 2-ways in the pods, Kenwood Excelon deck in the dash, Rough Country Stinger & Winch Plate, Trail Gear rear bumper w/ tire carrier, HiLift, Rock Krawler X Factor Plus Steering
ROLLTIDEtj is offline
post #4 of 19 Old 07-21-2010, 10:45 AM Thread Starter
reelnative
so are they usable and if so witch way do i mount the curve
post #5 of 19 Old 07-21-2010, 10:48 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Springs only seat in the perches one of two ways and in your case, bow forward or bow back.
Orient yours with the bow back.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #6 of 19 Old 07-21-2010, 11:28 AM Thread Starter
reelnative
so these are still ok to use
post #7 of 19 Old 07-21-2010, 01:04 PM
ROLLTIDEtj
That was just a guess. My springs were not bowed when I purchased them. I don't see any reason why you couldn't use them though.
post #8 of 19 Old 07-21-2010, 02:17 PM
leaf777
I just installed a RC 4" long arm and still use the stock sway bar, how would a stock affect the coils compared to an aftermarket?
leaf777 is offline
post #9 of 19 Old 07-21-2010, 02:19 PM
ROLLTIDEtj
My apologies, I meant to say track bar, not sway bar.
post #10 of 19 Old 07-21-2010, 06:10 PM Thread Starter
reelnative
so these springs should be ok to use ? seeing that they are bent will they still work ok or will i be changing them out soon, they both measure about 22in long but one is just a tiny bit longer then the other does it matter what side I put the longer one on
post #11 of 19 Old 07-21-2010, 07:17 PM Thread Starter
reelnative
bump
post #12 of 19 Old 07-21-2010, 07:24 PM
ROLLTIDEtj
I'm gunna go ahead and say that if blaine thinks they are fine to use then they are. When you say one is taller than the other, are you refering to the rear springs or front springs? if you are talking about the rears, put the taller one on the passanger side.
post #13 of 19 Old 07-21-2010, 07:41 PM Thread Starter
reelnative
yea one of the front and one of the rear are taller then the other
post #14 of 19 Old 07-21-2010, 11:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Put those on the short side of the Jeep. If you put them on the long side, it will be too high on that side.
I am Savvy
post #15 of 19 Old 07-21-2010, 11:21 PM Thread Starter
reelnative
hahahaha yea thanks
bowed , bent , coil , spings , defective , safe , help , advice , TJ
Bowed Front Coil Springs pfifer TJ Wrangler Technical Forum 21 09-17-2010 03:01 PM
New Coil Springs look bowed bigeasy TJ Wrangler Technical Forum 8 01-19-2010 06:18 AM
left front coil spring bowed forward? Alex74012 TJ Wrangler Technical Forum 4 01-11-2010 11:40 PM
Front coil lift springs TheBoogieman TJ Wrangler Technical Forum 3 08-05-2007 11:26 AM
GC front coil springs TheBoogieman TJ Wrangler Technical Forum 4 07-21-2007 05:45 PM
