Bouncy rear end - JeepForum.com
post #1 of 12 Old 03-30-2005, 09:50 PM Thread Starter
Dunesled
Dunesled's Avatar
Bouncy rear end
Since I had my TJ lifted about 7 months ago I have not put that much mileage on it. But one thing I have noticed is the a$$ end is extremely soft / bouncy with an adult in the back seat. Off roading is very difficult because every little bump I hit I have to slow down until it stops bouncing. It almost feels as if it's only riding on the springs. 4" stage 2 w/ 1" body. is this normal?
2000 TJ SPORT 4.0 AUTO, 4" PROCOMP STAGE II, 1" DAYSTAR BODY LIFT, 33" PROCOMP A/T ON EAGLE ALLOYS, 4.10 GEARING, PROCOMP 130W 6" ON WINDSHIELD MOUNTED BRACKETS. LoD REAR TIRE CARRIER.GREEN JEEP CLUB #115
Dunesled is offline
post #2 of 12 Old 03-30-2005, 10:07 PM
bfr
bfr's Avatar
what kind of shocks do you have?
bfr is offline
post #3 of 12 Old 03-30-2005, 10:56 PM
StealthTJ
Originally Posted by Dunesled
<SNIP>
. is this normal?
<SNIP>
Well of course NOT ... !!.....
As already asked, what kind (make) of shocks are you running in the rear.
BTW, they are new shocks, aren't they ??
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #4 of 12 Old 03-31-2005, 12:10 AM
got4-Lo
i bet he is running some pro-craps
stretched *** tj
got4-Lo is offline
post #5 of 12 Old 03-31-2005, 08:33 AM
Fritz R.
What kind of shocks? And are you running them can up or down?
Fritz
'97 TJ, 4.0L, AW-4, Flipped D300/4:1, ARB's, D44, Swayloc, RK LA, PC coils, Rancho 9000's, 33x12.5 Trxus, etc.
Fritz R. is offline
post #6 of 12 Old 03-31-2005, 09:07 AM
wayoflife
i agree, if you are running can up and they are not meant to be, you will have a dead spot resulting in a bouncy ride.
wayoflife is offline
post #7 of 12 Old 03-31-2005, 04:17 PM
fergyfer
fergyfer's Avatar
Looking at your avitar, I'd say it's not your rear that's bouncing
Green 99 Sahara
OME 2.5", JKS Discos, 31" Dayton Timberline MT's
IPF/PIAA Headlight Conversion
fergyfer is offline
post #8 of 12 Old 03-31-2005, 06:43 PM Thread Starter
Dunesled
Dunesled's Avatar
They are can up and yes they Pro Crap 3000 I think. Bad shocks perhaps?
Dunesled is offline
post #9 of 12 Old 03-31-2005, 07:11 PM
Fritz R.
The cans need to be down on the ES3000's. Flip them over and your bouncing problem should go away. When they are run upside down they develop a dead spot where the shock is doing absolutely nothing. This results in a very bouncy ride.
Fritz
Fritz R. is offline
post #10 of 12 Old 03-31-2005, 07:16 PM
Fritz R.
I should also mention when you flip them over, the ES3000's are a very stiff riding shock. Not valved right at all for a jeep. I ran them for a couple of years and was very glad to be rid of them. I also had them can up for a very short time, but didn't keep them that way for very long. One trip over some railroad tracks and my rear end came compleately off the ground. That was enough for me!
Fritz
Fritz R. is offline
post #11 of 12 Old 04-01-2005, 06:56 PM Thread Starter
Dunesled
Dunesled's Avatar
Are the MX-6 shocks any good for a Jeep? If not, what would you recommend?
Thanks for the help.
Dunesled is offline
post #12 of 12 Old 04-01-2005, 07:02 PM
JeepTJMan
I like my skyjacker hydro shocks they ride nice. And they are reasonably priced.
JeepTJMan is offline
RE 2.5. Why is it so BoUnCy!? Escape311 YJ Wrangler Technical Forum 17 02-05-2009 06:58 AM
Bouncy, Bouncy Bears Fan TJ Wrangler Technical Forum 7 04-25-2007 09:17 AM
Bouncy Rear wheel???? losfreddy TJ Wrangler Technical Forum 3 04-06-2007 06:02 PM
bouncy bouncy havokprod TJ Wrangler Technical Forum 1 12-23-2005 08:50 PM
Bouncy bouncy idle? BNovak TJ Wrangler Technical Forum 2 06-17-2004 10:39 AM
