Bouncy bouncy idle? - JeepForum.com
post #1 of 3 Old 06-17-2004, 10:28 AM Thread Starter
BNovak
BNovak's Avatar
Bouncy bouncy idle?
This kinda goes along with my other post on the bucking at 60.
At idle, I'm swigning between about 800 and 1200 RPM's.
Thinking this may be a fuel pump.
Thanks!
--BN
BNovak is offline
post #2 of 3 Old 06-17-2004, 10:33 AM
fyrfyter43
fyrfyter43's Avatar
Sounds more like a vacuum leak to me. Check all the vacuum lines, including the ones under the dash for the heater controls. Spray around the vacuum lines and intake, etc. with carburetor cleaner while the engine is running. If it idles up by about 100 - 200 rpm, you have a leak in that spot.
fyrfyter43 is offline
post #3 of 3 Old 06-17-2004, 10:39 AM Thread Starter
BNovak
BNovak's Avatar
Thanks for the tip. 150K miles, there's bound to be a vacum leak. I'll dig around tonite.
Thanks!
--BN
BNovak is offline
bouncy gas pedal JIBTEXHNKA YJ Wrangler Technical Forum 7 03-07-2009 02:25 AM
RE 2.5. Why is it so BoUnCy!? Escape311 YJ Wrangler Technical Forum 17 02-05-2009 06:58 AM
Bouncy, Bouncy Bears Fan TJ Wrangler Technical Forum 7 04-25-2007 09:17 AM
bouncy bouncy havokprod TJ Wrangler Technical Forum 1 12-23-2005 08:50 PM
bouncy/vibration red wrangler renegade YJ Wrangler Technical Forum 3 10-24-2001 05:11 PM
