Bought used Jeep with OME lift, how do I tell how high the lift is? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bought used Jeep with OME lift, how do I tell how high the lift is?
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 01-01-2007, 02:46 PM   #1
Baggerguy
I bought a 97 wrangler sport with a OME lift kit on it, how do you tell how high a lift kit was put on it? Looked at rear of transfer case and it does not have a SYE installed. Also has 31/10.5 tires, 20" from ground to rocker bottoms.
Baggerguy is offline   Reply With Quote
Unread 01-01-2007, 02:53 PM   #2
XabuJr
If it's OME and it only has 31's, it'd most likely be the default 2.5" OME lift.
Lack of planning on your part does not constitute an emergency on my part.
'88 YJ, 33's, auto, 4.2L. Many pieces waiting to be put in!
XabuJr is offline   Reply With Quote
Unread 01-01-2007, 04:38 PM   #3
nicolas-eric
for the TJ there is only a 2" OME lift. with the HD springs it΄s a 2.5" lift.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Unread 01-01-2007, 08:25 PM   #4
beryl
my 32's and a 2" coil lift is about 22" to the rocker panel. seems like you got a small lift. when i had 32's and no lift i was at 19" (so i got 3" out of it) but if your measurements are correct then it seems like you don't have the 2" or 2.5" OME lift. if you did your rocker panel would probably be at least 21" high.
beryl is offline   Reply With Quote
Unread 01-01-2007, 09:09 PM   #5
JeepGal
I fairly certain that the OME lift was limited to 2.5" due to regulations in Austrailia. They cant even call it a lift kit, its a suspension system.
Enjoy your "new to you" Jeep...Welcome to your newest addiction!
Tam
My Jeep Rocks!
JeepGal is offline   Reply With Quote
Unread 01-01-2007, 09:10 PM   #6
ColoradoTJ
While you can get 4" OME springs they are fairly new, It's likely that you have the 2.5" lift.
Clint
Colorado Jeep Club Member #60
My Jeep
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline   Reply With Quote
Unread 01-01-2007, 09:57 PM   #7
Baggerguy
Thanks for the help, my tires are about 50% or less so that would account for some of the difference. Don't know how long or how many miles the lift kit has on!
