Bottom bolt on front brake caliper stripped - JeepForum.com
post #1 of 2 Old 08-09-2008, 04:38 PM Thread Starter
athos76
Hey all... just changed my front pads and rotors out today, and while taking out the carrier bolts, the bottom bolt on one wouldn't budge (after spinning out most of the way) I thought it might have been stuck on the boot, so I gave it a light tug, well it came out fine.
Threaded it in while the caliper was off, and it was fine.... Put the rotor and caliper on, put the top bolt in loose, and put the bottom in, and it went in 3 or 4 turns and then started spinning in place.... so I pulled everything back off, lightly threaded a tap thru the hole and threaded the bolt in again.
It went in fine.... put everything back on... put that bolt in, and it got tight to where I was going to torque it to 10-11 ft lbs. and it started free spinning...
Rinsed and repeated the process.... Caliper off it threads in fine...caliper on it won't stay tight.... what should I do?
Also my Powertrain is still under warranty...should I take it in for this??!
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #2 of 2 Old 08-09-2008, 04:41 PM
HipCheck_1
Is this the dreaded problem that mrblaine has made a kit for?
http://www.jeepforum.com/forum/showt...aliper+threads
http://cgi.ebay.com/ebaymotors/Jeep-...spagenameZWD1V
I would venture to say that Jeep will blame you for causing it and would not honor it under warranty unless you can prove it was defective.
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 06:59 PM
Caliper bolt stripped, how to get off? TheDragonfly TJ Wrangler Technical Forum 33 12-22-2009 07:52 AM
Helicoil for Stripped Front Caliper?? gtospeeding TJ Wrangler Technical Forum 22 09-08-2007 09:50 AM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
Brake caliper bolt holes lifeguard4_00 YJ Wrangler Technical Forum 7 02-21-2005 07:15 PM
