bolt snapped in half from the door where the strap is - JeepForum.com
post #1 of 5 Old 12-11-2009, 07:31 AM Thread Starter
Mitchin
what do i do now it. worst part is usually noone rides with me and the one day i take my friend home from fball it happens so any help would be very much appreciated!
NIGHT CREW #16
Yellow Jeep Club #67
My Build Thread-
Mitchin is offline
post #2 of 5 Old 12-11-2009, 06:25 PM
ImaginaryFriend
ImaginaryFriend's Avatar
Mine did the same thing on my driver's side. I just took off the door panel, removed the broken bolt stud (drilled it out with a slightly larger hole-it didn't want to be extracted), and put in a new bolt with a washer and nut on the inside.
Only downside is you can't just unscrew the bolt from the outside (like stock) anymore, but other than a rare door strap replacement, there is really no reason to undo the bolt.
ImaginaryFriend is offline
post #3 of 5 Old 12-11-2009, 07:07 PM
tjchuck
agreed-ed, i drilled the bolt out and replaced it with a stronger bolt and that should take care of it for ya
tjchuck is offline
post #4 of 5 Old 12-11-2009, 07:09 PM
finalreckoning
I have the same problem on my driver side door.
I haven't fixed it yet, but I'm just going to extract it.
Green Jeep Member #273
High School Jeepers #169
finalreckoning is offline
post #5 of 5 Old 12-11-2009, 10:17 PM
2003RubiBlue
I drilled it out and replaced with a self tapping sheet metal screw....done.
Will work for Jeep parts...
2003RubiBlue is offline
Small Part Source - Door Strap Retainer Bolt bplv TJ Wrangler Technical Forum 15 12-12-2010 08:53 AM
Snapped bolt, door opens way too far now PDX_XJ TJ Wrangler Technical Forum 2 05-27-2009 03:14 PM
Half door restraining strap? ShinySideUp TJ Wrangler Technical Forum 3 03-30-2009 11:55 AM
Snapped off door bolt AZrattled JK Wrangler Technical Forum 16 10-23-2008 07:15 PM
Snapped door bolt? thebulkinator TJ Wrangler Technical Forum 7 07-19-2004 09:05 PM
