bolt problem not really jeep oriented - JeepForum.com
post #1 of 5 Old 06-21-2005, 05:33 PM Thread Starter
cspoffroad
I was hoping somebody could help me out with this. I bought a 4xrac to mount my hi-lift to the bumper. A couple of weeks ago i decided to take the hi-lift and move it into the cab. Now i have the 4xrac things still on. I got one off (4 bolts). I got 3 of the 4 bolts off on the other one bu the 4th one is stuck or something like it. Everything seems to be turning right but the stupid thing will not come out. I went to home depot and bought metal blades to fit the sawsall. I tried to cut the bolt off but that didnt work. Is there anybody out there that can tell me what i need to do in order to get this bolt off?
Thanks
98' Jeep Wrangler Sahara
Skykacker 4inch, 33x12.50 BFG M/T's, kilby steering skid, optima red top, flowmaster 40 series, airaid intake and TBS, bestop bikini and halftop, lock-right in Dana 30
"Are you locked up?
Yup, both doors!!!!"
cspoffroad is offline
post #2 of 5 Old 06-21-2005, 05:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You can't get to the nut on the other side to prevent it from spinning with a wrench?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #3 of 5 Old 06-21-2005, 06:20 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
wiz-wheel,
RnEmOvr is offline
post #4 of 5 Old 06-21-2005, 07:31 PM Thread Starter
cspoffroad
i can get a hold of both the nut on one side and the actual bolt head. I hold the nut tight and use a socket wrench to try and get the bolt out. I can turn and turn but nothing happens.
Thanks
"Are you locked up?
post #5 of 5 Old 06-21-2005, 07:57 PM
unrefined
unrefined's Avatar
Is the bolt threaded all the way to the head? If not and it has a smooth portion you may, emphasis on may, have ran the nut past the thread. You would have had to put some serious torque on it if the bolt was a softer grade. Ive seen it happen on some airplane components, but pretty rare. If thats the case just saw-zaw it off. Or attempt to anyway. Odds are this probably isn't the case but just a possibility. Good Luck.
Or if the non-threaded portion of the shank was a smaller diameter than the threads it could have ran off.
Air Force Jeep Club Member #10
unrefined is offline
problem tapping bolt M 88 YJ YJ Wrangler Technical Forum 5 10-22-2009 11:27 PM
Big Bolt Problem, need to know trans to motor bolt size FAST!!!!! antec YJ Wrangler Technical Forum 5 06-05-2009 11:39 AM
Seatbelt Bolt Problem jrs948 TJ Wrangler Technical Forum 4 08-05-2008 07:27 PM
stripped bolt problem mean90yj YJ Wrangler Technical Forum 9 03-31-2007 04:51 PM
soundbar bolt problem spinnjase TJ Wrangler Technical Forum 8 07-27-2005 12:12 AM
