Bogging down upon Acceleration with jerking and engine light flashing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bogging down upon Acceleration with jerking and engine light flashing
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Weekend Sale at JeepinOutfittersPoison Spyder from CCOR!
Unread 06-25-2012, 04:40 PM   #1
smorris3508
I have a 2006 Jeep Wrangler manual 6 speed with an inline 6. Over the past few weeks the engine will bog down upon acceleration no matter what gear I'm in and it start jerking and lose power and the engine light will flash, but its not throwing any error codes, until I push in on the clinch and reset it and then it seems to do fine most of the time. It doesn't do this everytime it just does it randomly. What could be the problem?? Help please!
smorris3508 is offline   Reply With Quote
Unread 06-25-2012, 04:55 PM   #2
flying_bosun
Watching Big Brother?
flying_bosun's Avatar
Cam position sensor, crank position sensor, clogged cat(s)? I'd suspect the first 2 since it's random. Could be other sources, too, but that's my 2˘.
Gear-Calculator Stu Can Help You Part Names and Numbers Dealer Supplied Parts and ask for "Jeep Club" Prices
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline   Reply With Quote
Unread 06-25-2012, 05:03 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Upstream 02 sensor is another possibility.
How many miles are on your TJ?
Wheelin98TJ is offline   Reply With Quote
Unread 06-25-2012, 05:57 PM   #4
tac426
throttle positioning sensor may be bad. should send the computer a code though. if it just started, it'll get worse.
tac426 is offline   Reply With Quote
Unread 06-25-2012, 07:21 PM   #5
FernBchJeep
The punk made my day.
FernBchJeep's Avatar
Another possibility is misfire due to plug misfire. Many manufacturers use a flashing CEL to show misfire. DTC's should give the answer.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 1924
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
FernBchJeep is offline   Reply With Quote
Unread 06-25-2012, 08:17 PM   #6
thn394
My 05 LJ just started doing the same type thing except I have no check engine light on at all. Under acceleration it will just bog down for a second like it's going to stall then pick right back up. I also get a stutter when sitting at idle like a misfire and it almost feels like it's going to stall but doesn't. I've got 67k on it and the plugs were done with factory plugs at 62K. I've owned several 4.0L equiped TJ's/LJ's and I've never experienced one doing this. I have not yet checked my OPDA, could wear on the gear cause this?
thn394 is offline   Reply With Quote
Unread 06-25-2012, 08:25 PM   #7
amiller
Just Curious, have you checked the OPDA?
amiller is offline   Reply With Quote
Unread 06-25-2012, 08:30 PM   #8
mmini1990
mmini1990's Avatar
TPS AND PPS. Clean your throttle body and tps. Check the pig tail for it as well. Bit it should be tossing a code. Hmm
MY BUILD
http://www.jeepforum.com/forum/f22/o...-rubi-1388971/
There are other ways of adding belly clearance without lifting your vehicle off the axles...like 40s, 42s, 44s, etc
Originally Posted by mike481
My jeep is magic...it can make all my money disappear.
that's not magic, that's standard operating procedure
"i dont understand why jeep made doors and tops an option, getting cought bare assed, pants around your ankels in a hail storm is half the fun of owning this *****"
mmini1990 is offline   Reply With Quote
Unread 06-26-2012, 01:14 AM   #9
ratmonkey
Living dead mod
ratmonkey's Avatar
All manufacturers use a fishing cel to singnify that there is a condition in the engine that is highly likely to lead to immediate damage of hard parts. This is a standard of the on board diagnostic system reporting rules.
99.9% of the time that's a serious or multiple misfire condition.
Not likely to be a throttle sensor. Crank sensor, plugs, injectors, piston failure, head gasket failure, opda wear. Are possibilities.
ratmonkey is online now   Reply With Quote
Unread 06-26-2012, 05:19 AM   #10
johnxjeep
Mine does the same thing once and a while even after changing the TPS . Not very often though.
There are a lot of threads on the subject and it seems not a lot of completed repair updates.
johnxjeep is offline   Reply With Quote
Unread 06-26-2012, 08:14 AM   #11
wkbear
Mine did the same thing, bogging randomly and even cutting off all together. CEL would flash, but no codes. I changed the spark plugs and it runs perfectly now (except for an exhaust leak). The old ones were gapped at .070". Mine is an '06 w/ 93K.
2006 Wrangler Rubicon, 6-speed, red
2005 Grand Cherokee Ltd., Hemi, QDII, silver (wife drives this one)
wkbear is offline   Reply With Quote
Unread 06-26-2012, 08:43 PM   #12
smorris3508
I haven't tried anything yet but there aren't any codes showing that anything is wrong. I am currently at almost 58k mi.
Unread 06-26-2012, 08:45 PM   #13
smorris3508
Thanks for all the input! Once I figure out the problem I will post and let you all know what I found.
Unread 06-27-2012, 03:24 PM   #14
ripper5000
I have an 06 LJ same mileage and just recently replaced the oil pump drive gear I believe was the name (where distributor is on earlier models). While I was replacing it I also did spark plugs and now I am experiencing the same symptoms. A slight "bogging" down on take off and a low rpm idle (around 800 rpm) I believe I have a small exhaust leak just before the muffler if this makes any difference. If I manage to figure it out I will let you know what I did. It seems there is a list of things it could be.
ripper5000 is offline   Reply With Quote
Unread 06-27-2012, 06:03 PM   #15
Tblack
A flashing check engine light isn't something to take lightly.
And No, a flashing CEL does not mean missfire.
It means that there is a problem with the engine that can cause serious damage.
A solid illuminated CEL means that something has happened that will cause the emissions to exceed 1.5 times the FTP.
Flashing means a failure that will cause damage. That is why they tell you to pull over if a flashing engine light occurs
Safety 3rd!
Tblack is offline   Reply With Quote
