body wobble - JeepForum.com
post #1 of 10 Old 09-18-2011, 08:37 PM Thread Starter
leapfaith
body wobble
I just put not shocks on and I'm getting body wobble. The sway bar connecting rod keeps stripping out which I think is part of the problem. Is there a reason it would continue to strip these. Also I noticed rubber bushings between the frame and where is mounts to the body. Would replacing those get ride of my body wobble?
leapfaith is offline
post #2 of 10 Old 09-19-2011, 08:53 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
If your Jeep is an 01 it is not a JK it would be a TJ.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 10 Old 09-19-2011, 09:34 AM
1222
RIP John
1222's Avatar
to the forum.
Definitely not a JK since you’ve had it for six years and it has a 4.0 engine. Try the TJ tech forum for more results. One other thing to look for would be the control arm bushings to see if they are worn out. When you say wobble do you mean side to side while just off roading or is it during street driving? Can you be a little more specific and any way to post a pic of the part that keeps stripping out, it would help a lot to diagnose your problem.
1222 is offline
post #4 of 10 Old 09-19-2011, 10:48 PM Thread Starter
leapfaith
Thanks all for the feed back. I will get info and a picture up soon.
post #5 of 10 Old 09-20-2011, 12:31 AM
mediumdaddy
those little bushings between the body and frame need to be there. they are there from the factory. do not remove them.
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #6 of 10 Old 09-20-2011, 06:28 AM
MotoSoul
I am going to assume that the cup right where the end link connects to the sway bar has come apart. Just go buy a new sway bar end link and put it on or if you plan on modifying the jeep in the future a set of quick disconnects. Driving around with your sway bar half connected makes for some really weird handling dynamics.
MotoSoul is offline
post #7 of 10 Old 09-24-2011, 11:17 AM Thread Starter
leapfaith
T
post #8 of 10 Old 09-24-2011, 11:18 AM Thread Starter
leapfaith
[QUOTE="leapfaith"]I understand the bushings between the frame and body are from the factory. My question would that give me unusual body wobble. I just replaced the swaybar link and that helped. Also replaced the steering rod shock. That helped a lot of the movement. It still feels like the body is floating a little like a bobble head.
post #9 of 10 Old 09-24-2011, 12:43 PM
MotoSoul
Your body mount bushings have nothing to do with the "wobble" you are feeling unless they are not torqued down or your body is rusted out where they connect. You really need to define the whole wobble bit for anyone to help you any further. Either your shocks are toast which will cause it to almost float instead of being firm or you have parts in your steering system that are worn out.
Did you replace the swaybar link and the steering stabilizer at the same time or seperate? Did you check the rear swaybar as well to make sure the links are still good on it as well?
I might also suggest you do a dry steering test to see if you have any play. Have someone in the Jeep turn the wheel back and forth a little bit. It only needs to be just past the point where the wheels start to move. If anything has give before the wheels start to move then you have a problem.
MotoSoul is offline
post #10 of 10 Old 09-24-2011, 03:09 PM
mediumdaddy
[quote=leapfaith;12218542]
have you checked all of your body mount bolts to make sure they arent' loose?
Utah Jeepcrew #63
body , chassis , frame , suspension
Body Lift Causing Death Wobble? elupton TJ Wrangler Technical Forum 59 11-16-2011 06:42 PM
Wobble at 35-45mph but not death wobble cyber1satan TJ Wrangler Technical Forum 5 02-24-2011 05:24 PM
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 08:25 AM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 01:29 PM
wobble problem (not death wobble) mkalcevic TJ Wrangler Technical Forum 6 07-27-2006 04:56 PM
