Body mount torque specs? - JeepForum.com
post #1 of 10 Old 05-22-2005, 06:13 PM Thread Starter
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Searched. I have 04 FSM & can't find it in there (body mount might be called something else?)
What is the torque specifications for the stock body mounts?
I've read 35 ft. lbs, till the rubber bulges, till you grunt and then a little more, goodntight, etc.
2010 Sahara
04JeepTJ is offline
post #2 of 10 Old 05-22-2005, 06:18 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
35lbs on one in front center and 50 on rest
RnEmOvr is offline
post #3 of 10 Old 05-22-2005, 07:41 PM Thread Starter
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Wow. That seems like a lot. I tried torquing the body sides to 35 and it REALLY made the bottom rubber piece bulge. I torqued all of them to 20 so lets see if I fall off my chassis on my way to work tomorrow
Are the specs you quoted in the FSM somewhere?
2010 Sahara
04JeepTJ is offline
post #4 of 10 Old 05-22-2005, 09:12 PM
Rocky529
Rocky529's Avatar
I have all mine down to 35 ft./lbs. after I installed my body lift.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 10 Old 05-23-2005, 08:40 PM Thread Starter
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Wouldn't that high of a torque squish the rubber bottoms so much that the metal part under the bolt head would contact the metal sleeve? Why not just use washers instead of that metal thing.
Something tells me it should be enough for the body to float a little for when the chassis flexes...
2010 Sahara
04JeepTJ is offline
post #6 of 10 Old 05-23-2005, 09:16 PM
Jim Shanks
Jim Shanks's Avatar
35 ft. lbs. and some thread lock. Just the blue kind.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #7 of 10 Old 05-24-2005, 06:03 AM
penguinland
penguinland's Avatar
They are called "Main Floor hold down bolts" in the FSM and the torque spec is under the frame/bumper section not the body section
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
post #8 of 10 Old 05-24-2005, 06:37 AM
SeaHoCapt
Jim
Thats what I did
David
'97 TJ Sport,
3.5 lift (OME 2.5" SL, Daystar 1" BL, JKS 1" MML)
33x12.5x15 MT/R's on 15x8 MT Classic II
YORK OBA
Warn 95ti
SeaHoCapt is offline
post #9 of 10 Old 05-24-2005, 03:23 PM Thread Starter
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Sweet. Thanks, guys. I'll make the adjustments!
2010 Sahara
04JeepTJ is offline
post #10 of 10 Old 06-04-2005, 12:45 PM
blacksheep1
had the same prob. couldnt find the specs in the FSM. after looking at this thread i found the specs on a table in the front of the frame/bumper section as stated. however the specs for mine are listed as follows:
main floor hold down bolts-50 ft/lb (the six larger bolts)
radiator to frame mounting bolt-45 ft/lb (the centered one in front)
rear floor to frame mounting bolts-35 ft/lb (the remaining four bolts in rear)
although the FSM doesnt have a diagram listing which bolts are which i'm sure the info in ( )'s is correct.
3 Jeep family again.
MINE 1999 TJ sport, HERS 2004 KJ Renegade and 2005 Rubicon
Wind Tunnel Tested . . . FAILED
blacksheep1 is offline
Body mount Torque specs? mde YJ Wrangler Technical Forum 7 01-21-2010 04:09 AM
Body Mount Torque Specs? JBWood05TJ TJ Wrangler Technical Forum 2 09-07-2009 04:42 PM
Body mount torque specs.... Ryans_GP YJ Wrangler Technical Forum 0 11-26-2004 09:53 PM
Body mount torque specs? blackw YJ Wrangler Technical Forum 11 04-27-2004 11:41 AM
body mount torque specs Bucket110 TJ Wrangler Technical Forum 3 08-23-2003 12:26 AM
